8030 fluid question
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Topic: 8030 fluid question
    Posted: 19 May 2012 at 5:14pm
we have a 8030 2wd with power shift it has started pumping hydrolic fluid into the power shift compartment untill it over flows  any body run into this before what could cause this Confused
AC200Puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 5:45pm
It is caused from the seal in the pump on the belly of the tractor it is I believe the one on the gerotor pump but if I am down there I take care of all my leaks pretty easy fix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 7:08pm
Anytime I've had a bad shaft seal in the gerotor pump, it sucked transmission oil level down and put it in the rearend. More info needed.....hours??....how long has it been doing this??? how much oil transfer in a day?? does it transfer more when roading at 20 mph than it does at field speeds??
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 9:24pm
sorry will have to call over to the farm in the morning to get details we have been baling hay all day just sat down for dinner
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 9:29pm
There are alot places it can transfer oil. There are steel plugs that can rust holes in them, pinion seal, but the seal on pump drive shaft is the 2nd most likely place to leak. Seal in gear pump is the most likely.
  Any time you have the pumps out is a good time to replace the seal on pump drive shaft. It can be removed and replaced through pump hole.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 9:36pm
4400 hrs just started dosent mater road or field  pumping 2 to 3 gal per hour from rear hydrolic to powershift untill over flows out vents
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2012 at 8:22am
If it transfers that much, it is gear pump.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2012 at 10:02am
Yup gerotor pump seal easy fix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2012 at 4:54pm
thanks all will drop the pump and see whats going on
This page was generated in 0.035 seconds.
