ac tiller
kyle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kyle Quote  Post ReplyReply Direct Link To This Post Topic: ac tiller
    Posted: 12 May 2012 at 1:32pm
i bought a ac front tine tiller with a reverce on it but the belt was off and i do not know how to rought it on so it will turn backwards does aney one have a pic to show me thanks kye
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 3:39pm
What is the model # of the tiller? Is this a vertical or horizontal shaft engine that drives the tiller? Most of these tillers had a pulley on the camshaft that ran the reverse. Could be you have the shaft coming out the engine pan and your missing the pulley. Could be a later model tiller that uses a series of idler pulleys to ride the crank pulley and drive the reverse.
A pic of it would help out a lot.
Yea, I can fix that.....
kyle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kyle Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 3:57pm
dave the shaft is horisontal it does have the idler set up on it one is flat for the back of the fwd belt and the other is a v which i think is for reverce! the model that i got off the ac tag is 997543475 hope this will help me and you to identify it thank kyle
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 8:06pm
Sounds like a Simplicity tiller I recently traded off. The reverse belt routes with the flat side up around the idler above the engine pulley. When you engage reverse the idler assembly moves  over and forces the V of the belt into the engine pulley secound groove, driving the tine pulley backwards. I hope this helps cause now I'm confussed.
kyle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kyle Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 9:08am
dave thanks for help!  i think i know what u are talking about i will look
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 6:54pm
I got out to the shed today & was able to take a few pics for you. Don't know if this is your model, but hope it helps.
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2012 at 7:12pm
I have one of these also and it runs like a top.  It's a 5hp.  What size is your engine?
