226 Power Unit Question |
Post Reply ![]() |
orangeman ![]() Orange Level ![]() Joined: 12 Sep 2009 Points: 1852 |
![]() ![]() ![]() ![]() ![]() Posted: 10 May 2012 at 4:30am |
Guys: Has anyone here used a 226 power unit engine in a D17 Series IV tractor.
Any modifications to contend with, I am assuming the power unit is a direct bolt in replacement, but have not done this conversion. Any comments or thoughts would be great. Thank-you...Orangeman PS - Is the radiator in the power unit the same as in the D17 tractor? Reason I ask is that some of the smaller AC power units like the 149 the radiators are not the same as in the tractor.
dustinmo ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Auxvasse, MO Points: 2187 |
The rad in my g226 power unit is not the same rad as a 17, and as for putting the engine in a 17 I dont know why it wouldnt work, but I would think if you had a g226 power unit you should be able to sell it and make enough to put a little cash in your pocket and buy a gleaner E engine to put in your 17
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21834 |
It needs to be a G-226 power unit, not a W-226 power unit.
Hello Dr. Allis: Can you give me some tip on the difference between the G and W 226 power unit models.
Thank-you Orangeman
W-226 is commonly used in the WD45 application. The G226 was first used in the D17 application and later on the 170-175 and E and E3 Gleaner combines. Look at the serial number behind the carb air inlet hose stamped on the block. If it says 45- XXXXXXX it's a WD45 engine. If it says 17-XXXXXX it's a D17 engine. There are also several other ways to ID which one it is.
Dr. Allis Very helpful will look for the 17 -xxxxx appreciate the help.
Ok guys I did positively identify that it is a W-226 power unit as it starts with 45 xxxxx on the block.
Question - Can the W-226 go into a WC tractor without mods? Thank you for any comments or help. Orangeman
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Are you saying a W226 engine won't bolt up in place of a G226? I always thought you could bolt a 17 engine in a WC and visa versa. Edited by CTuckerNWIL - 11 May 2012 at 8:10pm |
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4540 |
As far as bolting in, both G and W 226 engines are the same. The G 226 has a rib cast into the block on both sides just above the oil pan and also has 3" mains instead of 2.5" so is a more robust engine.
Calvin and Charlie: Thanks for the info. That is quite a jump from 2.5 to 3" mains.
We have a few WC around our area that could use a donor engine, so was thinking the W-226 could go in place of the old WC engine. When did Allis start to equip the 226 block with a Dry element air cleaner?
Post Reply ![]() |
