8070 pd shifting |
Post Reply ![]() |
Leon B MO ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2186 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Apr 2012 at 8:43pm |
Neighbor has a power direct 8070, I am not familiar with the pd trans so here is his question. He is wondering the best way to get the tractor moving in road gear without almost killing it on take off. Is there an option of shifting on the fly at all or do you have to start out in road gear and slip the clutch.
Thanks all.
Leon B MO
allis4ever ![]() Bronze Level ![]() Joined: 05 Nov 2009 Location: central iowa Points: 78 |
While not the proper way to do it---unless I am pointing downhill on start up I will go from 2nd to 5th on the go, after a bit you get pretty good at it without much if any grinding. If on a pretty hard surface with not too big of a load then I will sometimes start out in 5th and clutch a couple times to get it rolling.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8613 |
at lower rpm you can clutch shift with minimal grind. 4-5 seems the most awkward. I don't pull loaded wagons just tillage tools but I start in 3rd and shift up mostly.Some 5th gr starts on solid driveways........just remember not to "hit" the clutch brake unless you can hit it for the exact amont of time
Amos ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ontario Points: 1318 |
I have an 8030 pd, I shift it just like my 13 speed in the Frieghtliner, only thing is you need three hands to work the throttle and the gearshift, if you want to steer at the same time . It is a real nice transmission to shift once you get used to it, so was our 8010 pd when we had it.
Hurst ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Midway, Ky Points: 1218 |
No reason you can't shift on the go if you can properly rev-match it, just be gentle but quick so you don't grind the gears but at the same time, you don't want to "grab" or "catch" a gear really harshly.
Hurst |
1979 Allis Chalmers 7000
5800 Hours |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21847 |
We lost a lot when we lost the foot accelerator from the 7000 series. You could shift them without the clutch on the roll.
Thanks guys, I will print this out and give it to him.
Leon B MO
ILGLEANER ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
I agree with you on that Dr. Allis. That is the worst thing about the 8000 series,no foot throttle.
IG
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29805 |
Can't a foot throttle be added easily? Of course most everything I do that looks easy ends up three times harder than thought.
Wink I am a Russian Bot |
Lonn,you sound like my wife....but you've also answered that question
Post Reply ![]() |
