200 hyd pto front shaft housing removal- dowel pin
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 200 hyd pto front shaft housing removal- dowel pin
    Posted: 29 Jan 2012 at 2:15pm
Workin on a 200 AC and have to remove the pto front shaft housing - there are 2 dowel pins - are the dowel pins threaded in there ? I thought an Allen wrench should take them out but the holes looks round inside and cant get an Allen to bite in - unless someone else has been in there already and stripped them out, uuugggghhhhh , anyone know ?
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 2:25pm
I think they are tapped 1/4-20.
"Burgie"
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 2:41pm
They are 1/4-20. A slide hammer usually works.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 3:57pm
Yes , they are tapped - cannot get them to budge - i need to make a puller of some sort , maybe a short piece of small pipe ? I,VE NEVER SEEN DOWELS LIKE THIS !!! now what - Thanks !!
Edited by DougG - 29 Jan 2012 at 5:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 4:32pm
May have to heat the housing.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 8:53pm
No don't heat the housing. Use a slide hammer and they should come out.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 12:27pm
Good news !! [ for once] I bought a slide hammer at an auction a few years ago - never used it till today , made an attachment for it with the correct bolt size - a couple good whacks and they poped right out ; Thanks !!!
