What type of Paint gun do you use?
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Topic: What type of Paint gun do you use?
    Posted: 07 Aug 2011 at 8:00am
Hello again folks,
All of my painting career (which has been one tractor :-)  I have used a suction style high pressure paint gun.
I am looking to buy a better gun (HVLP) for my 17 project, Since we paint the bottom side of these tractors, which type of gun works the best on the bottom end?  A gravity fed, or suction fed, or do you use both, gravity on mid and top, suction on the bottom?
Thanks
Anthony
Still in use:
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 8:37am
I am thinking the same thing Anthony - dmaybe retire the antique Binks.
I think the idea of the cup liners that I see harbor freight advertize may be the cats meow.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 9:57am
Save your money and get a cheaper one unless your starting a busuness of painting and already have the skill down pat.
A years or so back on the Speed channel they painted a show kit car with a 60 dollar HVLP gun to show it is the painter not the gun that does the fine work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 10:05am
The guy who did all the painting at the Chevy dealer I was at said pretty much what Dick says. Walt told me once that he couldn't see any difference in results between an expensive De Vilbiss gun and the cheap Harbor Freight gun. Now when the HF gun needs rebuilt, just toss it and get a new one. At that time Walt had been painting cars for 25 years.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 10:07am
Tiberius T9.1 Elite.
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 10:49am
I have several that have accumulated over the years. A Binks Model 7, Harbor Freight Siphon Feed, HF Gravity Feed HVLP, HF Gravity Feed Touchup, and a couple others that I don't know the name of.  I mostly use the HF HVLP and the HF Touchup.  They seem to have less overspray. Have used the HF ones for enamel and base coat/clear coat and they do fine.  At my level, I can't see paying $300 for a paint gun.  Practice, practice, practice, works for me.  FWIW  :)
Edited by Osage_Orange - 07 Aug 2011 at 9:48pm
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 11:19am
Got HVLP one from Lowes.  Including moisture trap and fittings I have less than $125 in mine.
Greg Kroeker
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 11:34am
Harbor fright gravity feed low pressure. 14$
Bob, North Carolina
1949 B
one54dodgetruck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 12:11pm
+100, get them on sale for $12 and use one for a project and throw it away. I have a buddy with a painting shop that uses those for primer and base, but uses one of those fancy high dollar ones for clear.
Andrew
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 12:38pm
It may be my painting style but I find the binks no 7 syphon spray gun lays down a nice job when using industrial tractor single stage paints. I find the hvlp does a better job on the automitive 2 to 3  stage paints.  paint preperation and a paint booth also goes a long way.Jmho
Edited by mlpankey - 07 Aug 2011 at 12:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 12:38pm
To clarify, I am not going to get a 500 dollar gun, just want to get an HVLP, so I was wondering wich one works best UNDER the tractor?
But you are correct, it is not the arrow, it's the indian!  :-)
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 12:41pm
so wich paint system do you plan to  use 2 stage or 3 stage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 12:42pm
OK,
back to the question at hand.
For under the tractor, shooting up, which style, gravity, or suction???  That's all I want to know. Respectfully forget about the damn cost
Still in use:
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 12:43pm
Originally posted by Orange Blood Orange Blood wrote:
OK,
   Suction.
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 12:48pm
OK,
automotive 2 stage or 3 stage or single stage tractor paint ?answere the damn question. so you know the binks number seven conventional gun  is around 4 to 500 new
Edited by mlpankey - 07 Aug 2011 at 12:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 12:56pm
OK,
Maybe, I am not very good at asking the question, but I am sorry you still haven't answered what I am looking for.
So here it is, as plain as I can make it.  When any type of paint gun, shooting any type of paint upwards, where the gun is below the paint stream at a severe angle, which works best a suction or gravity?  If the gun is half full, I have to think the suction will stay in the paint longer, since most of the gravity guns lay the can back toward the operator, the paint would fall away from the opening faster than the suction gun, but I don't know, that's the whole reason for the question of you who have been there.
Forget about the type of paint, the cost of the gun, whether it's HVLP or not, just the location of the paint sorce, vs. the angle of the spray
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 12:56pm
I take it you don't want to do it my way.
I would say the suction gun would be the answer to your question.
Edited by Dick L - 07 Aug 2011 at 1:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 1:00pm
That's not a half bad idea, it never occured to me, my D17 rear end, will be heavier, but I will think about it.
Still in use:
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 1:00pm
That sums it up Dick :)
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 1:01pm
OK,
think about it .are you asking if a gravity feed gun will defy gravity?
Edited by mlpankey - 07 Aug 2011 at 1:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 1:02pm
How hard was it to get it back over, without any paint damage from handling?
Edited by Orange Blood - 07 Aug 2011 at 1:24pm
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 1:03pm
OK,
Exactly, that's what I don't know, how far back can you tilt the gravity gun, before the paint falls away from the pickup?  Can it shoot near vertically up? I know that too far up on a suction gun will run out of paint too?  So which is better?
Edited by Orange Blood - 07 Aug 2011 at 1:04pm
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 1:15pm
This is why i have 3 over head hoists that are capible of lifting the whole tractor up on end.
Andrew
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 1:22pm
Orange Blood,  I am not a pro painter.  My Waggoner HVLP - HLVP? spray gun has a angled suction tube (30 degree bend on it?) inside its 1.5 qt container(cup).  I have had good luck in just turning the suction tube towards the back of the gun's cup for spraying upwards or overhead.  It will work just fine for just over half the volume of the container before it begins to sputter out of paint.  Depends on the angle of spraying.
If I am going to be spraying downward (like over a car hood) position, I just turn the suction tube toward the front of the sprayers cup.
Dick, I like your idea of turning the piece over for a greatest positioning.  I do that a lot when welding/fabricating if it is possible.  Nothing like being comfortable at work....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 1:31pm
Orange Blood, sorry I did not answer your angle question.  With my gun setup for overhead spraying, it will spray at any vertical angle as long as its has paint to suck from the cup.  I always try to paint the most demanding angles first with a new cup full.  I have no problems spraying directly overhead - straight up.  As paint volume decreases, then so does the angle of spray
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 1:37pm
Guys, I don't want anyone thinking I am mad at them, I was just frustrated that the topic whent were I didn't need it to.  Everyone offers great ideas, and for that I am thankful, but my mind is made up about the HVLP, and the cost $50-100, I just wanted info on suction or gravity, since I had no exeriance with a gravity gun.  Your info was helpful, and I am sorry to any of you who might think I was being childish, it was not my intent.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 1:40pm
I slid the cast centers back on and flip it back over with the engine hoist. No paint damage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 2:00pm
I am very intrigued by that idea, I think I will go do some measuring, to see if I can do that with the 17 right now!!!
Still in use:
MUM FARMER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MUM FARMER Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 2:17pm
Just a bit of information someone put me onto very slick system youtube 3m pps system primer gun with disposible tips and adapters to use cup setup on any gun check it out
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 3:37pm
This is my line-up, all from Harbor Freight. I think the trick is getting the mixture right but I'm no painter.  The gravity feed came with a tip for primer that works pretty good for the epoxy primer if there is such a thing.  I got the one on the right just for what you are talking about.  I used an emailed coupon and it was about $40, I don't remember what I paid for the filter/regulator that I got to go with it.  I did the under side of the WC with the gravity feed one, wasn't easy and had paint come out of the top a couple of times trying to get to tight places.  I do use the liners in the left one.  I like the idea of the disposable tips, it seems I spend more time cleaning my paint guns than I do painting.
This page was generated in 0.087 seconds.
