7060 maintenance
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Topic: 7060 maintenance
    Posted: 25 Aug 2026 at 7:05am
So i took the belly pan off to find quite the collection of oil,dirt and soybeans on the pan. Power washer worked well but blasted myself also. The leaks had me very concerened since I drove tractor 40 miles home,i have seen pictures of running a dry pinion. I did check site glass but must of mistaken. I took either to fine clean and found the large steel lines x3 going to the belly filter aera, pump supply and return, were seeping at the flange aera. Concerened with what kind of trick bag I was about to open I was pleasantly surprised how easy the fittings came apart, by the way one of the two pipes is larger so different part #.
I dumped up all the oil i didn't spill and have 22.5 gallons to take to my friend's business so he can heat with it. My books says 24.1 for total transmission and differential so thank God I wasn't too far off.
I have the NEW plastic piece for the powershift filter comming along with the new squish seal for the hydraulic line.
Pictures comming.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2026 at 4:48pm
When I pulled these tubes out to replace their seal I felt oil in the upper tube hole on the left so I got my Mighty Vac and pulled better than a gallon more oil out, it did look like it needed changed.
Anybody doing a fluid and filters on the rear on one of these should count on changing out these seals, easy.
Waiting on the USPS to deliver the power shift filter part.
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2026 at 6:18am
I kinda feel like I'm tooting my own horn here but I am only looking for help with doing these what I call catch up maintenance items. I have yet to buy anything whether it be a car motorcycle or tractor that I can fully trust the previous owner when it comes to condition or upkeep. So I find myself doing these basic catch up things to my tractor. Yes we had one on the farm 46 years ago and for awhile I didnt want to rember. So that's why I ask for any hints. I was scared to death I was going to twist off something messing with the transmission and differential but turns out Allis built it to be worked on.
So next up will be fuel and coolant flush so #1 is there only two drains, one on bottom rt raidiator other is the line going to coolant filter. I always like to pull bottom hose off on old cars but doesn't look like it can be done. Book says 32 quarts, is that with cab? I drain then fill warm and drain and again if needed till clear then half capacity = 4 gal here then distilled water, do I need to allow more antifreeze?
#2 best less messy and less air to bleed way. Book says something about line after secondary filter going to pump having a T and a bleed spot? I know about the bleeds on top of the filter housings. 81 model with electric pump.
Edited by whatscooking - 28 Aug 2026 at 6:24am
68 D21 81 7060
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2026 at 6:27am
Getting the bottom hose off is doable though I found it difficult. But that doesn't drain the block. Found that out the hard way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2026 at 6:01pm
Anybody have a, better way, to seal that bleeder thumscrew on top the secondary fuel filter. Put new thumscrew in used old washer now leaks. Will a O ring hold here?
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2026 at 6:58pm
is this a copper washer ? ... They get WORK HARDENED and grooved from use.. if it has deep grooves, lay on a 150 grit sand paper and push it around to get if FLAT ....WE use to heat them up with a propane torch and let them cool to anneal them back to SOFT.... You could also go to NAPA and they probably have a GENERIC copper washer for fuel lines... I doubt an o-ring would fit.. would squeeze out and fail.
Edited by steve(ill) - 28 Aug 2026 at 6:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2026 at 7:14pm
I think the leaking part is one of those flat washers with a rubber Oring built into the I.D. of the hole. So, a flat washer with an Oring laying inside it it to contain it would work as long as the Oring is slightly thicker than the flat washer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2026 at 7:34pm
Its a plastic thumbscrew, not made to bear down on, the washer looked like metal of all things. I squeezed her tight and will see tomorrow if not iam digging in motorcycle leftovers.
68 D21 81 7060
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2026 at 8:10pm
As far as coolant goes 32 quarts is very close with a cab.  Just did my 7040.  I recommend the prediluted pink antifreeze made for diesel engines to prevent cavitation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2026 at 8:51pm
Whenever I drained a 7060 radiator (for a split) there was 5 gallons in the bucket. The block wasn't drained.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2026 at 3:44am
The block drain going to the coolant filter looked like about a five inch rise going to the filter. Put a wrench on the fitting to take it off but stopped. I filled and drove then opened raidiator and removed filter about five times. Refilled with almost seven gallons,that means if it holds 8 there was a gallon hiding, used 4.5 gallons of green concentrate and distilled water.
Edited by whatscooking - 29 Aug 2026 at 7:26am
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2026 at 3:44am
Got the coolant to -35. Bomgarrs has quite the collection of sealing washers so now my bleed fuel filter ports can be turned by finger.
I am doing things to the tractor in order to be ready to hook onto an 18 ft renovator that a neighbor offered to let me test out my tractors on after beans are done.
Next up is to tackle the heat blast I got on the 40 mile trip. The guy i bought the tractor from updated the system but wasn't happy with the performance, I had the windows open before I made it home. BUT, the hot air comming from around the throttle,steering column and pedals was like standing in front of a heat duct and i can see daylight on top and botttom of the door. I've looked and can see the foam has shrunk in the dash. When i redone my Firebird I used Dynamat under the carpet with great success.
Will a front rim and a exhaust pipe exchange between a 7060 and a D21?
Edited by whatscooking - 31 Aug 2026 at 4:27am
68 D21 81 7060
