185 right hand step
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Topic: 185 right hand step
    Posted: 14 Aug 2026 at 4:24pm
Were these an option all along or was it one of the things added towards the
end of production?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2026 at 5:43pm
I have never seen a factory one. Seems like a good way to get hurt!
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2026 at 6:29pm
I can't answer for a 185 but I have two 190XTs with that step, a seriesI and a seriesIII. They were old when I bought them, so it may be that they were added at some time. I have to agree with Tracy, there is no good reason to try to get on or off the tractor on that side.
Ted
190XTD seriesIII, 190XTD seriesI, maroon belly 7000, 7030, 7045, D14, 190XTD series??? project(or maybe parts)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2026 at 7:53pm
Ted
This one is different than the 190 step. Very similar but still different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2026 at 9:14pm
Allis NEVER EVER offered a right hand step for a 180/185 tractor. I personally know a man who was killed by a homemade step like that. There is no positive neutral lock for the Power Director handle. Besides crawl over and around those brake pedals......not easy.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2026 at 11:05pm
should never get on and off any equipment on the right side     i about droped a load getting on my fork lift on the right side and bumped the tilt lever    a few months ago  that kept me reminded to do things the right way ,   that goes right along being in the seat when you start somthing in case sothing goes wrong at least you wont get hurt or run over
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2026 at 8:25pm
I have a 180 that has an identical step. I will take a picture and post it.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2026 at 6:30am
Why is it dangerous as long as you're in neutral?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2026 at 7:46am
Because it doesn't always get put in neutral.....if all the stars align...it just takes once.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2026 at 7:49am
Go waaay back to 1957 with the early D-14 and D-17 tractors. Neither of them had a "thumb guard" around the top of the Power Director clutch. I think by 1959 sometime, the hand lever was changed to have that guard so when someone mounted from the right side and used the hand lever to pull themselves up and on the tractor, they didn't push down on the button (accidentally) and pull it into high range and run over themselves. A 180 or 185 only has a "detent" ball to hold it in the neutral position. One can easily bump the lever and if the transmission happens to be in gear (which it shouldn't be) the lever will probably get pulled into high range. If you notice in that picture, the hood handle is mounted vertically, which AC never did. The left side hood handle is horizontal and there is a hole in the hood for that. Not so on the right side. Again, AC never offered such a feature for those two tractors. All homemade or some small short-line company made and sold some at a great safety risk. It also appears that the corner bracket is made of diamond-plate material, which if AC did manufacture it, wouldn't have been what they would have made it out of.
Edited by DrAllis - 17 Aug 2026 at 7:52am
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2026 at 5:24am
When I was a kid, remember a neighbor getting run over by what must have been a 180 or 185. He had the PD in neutral, but not the transmission, and tried getting onto it from the right hand side. He must have grabbed the PD lever to pull himself up, and pulled it into gear. He lived to tell about it, but he did get hurt. Of course, whole community rallied around allis being bad bad bad, but really.....?
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2026 at 5:39am
I suppose I can see that. I guess I grew up on other colors and you HAD to put in in neutral. My tractors alwasy creep so much wiht the hand clutch or power director in neutral that it never occurred to me to leave that in neutral. If I did that it would always run me over right or left side.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2026 at 7:46am
I'd never trust the PD in neutral on any AC tractor I've owned to get off and on the tractor,just drop the transmission in neutral and be sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2026 at 6:34am
X2
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2026 at 8:40am
not just the tractors with the big stick , stands for most all equipment
gleaner1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gleaner1 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2026 at 6:57pm
Whats really odd is for some strange reason Allis put right side doors on its last tractor introduction the 8000 series.
ALLIS CHALMERS "The color is orange"
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2026 at 1:39pm
I finally remembered to take a picture of the right step on my 180. It is very similar to the one above. I know Doc says Allis Chalmers never made a right step, but someone did, maybe aftermarket?
I bought the 180 in the picture in northern New York State.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2026 at 2:33pm
One thing about people commenting about getting on a tractor on the left side was if you were still using an All crop combine and you went from a WD series to a D series and 100 series The combine was on the left, so you were walking in standing grain. When everything was running on the right-side mounting on the left became normal. The exception is running a silo blower. You pull up with the wagon to the right side of the blower tractor and want to hop on from the right to turn the blower on. I know about a fatality where a guy was mounting or dismounting a red tractor on a manure pump and grabbed or caught the wrong lever.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2026 at 4:33pm
Several years ago, we had a neighbor who was dismounting a (Deutz) tractor on the left side, with it running. They figured that he either kicked or got his pants caught in the shift lever. It ran over him.
He was conscious when we got there. I was the EMT on the call for our local volunteer fire/ambulance department. When we arrived on scene, he talked to me and called me by name. As soon as we extricated him, he coded and we lost him. The doctor in the ER later told me that they couldn't have saved him if it happened in the hospital parking lot.
I guess the moral of the story is that any running tractor can be a potential life-threatening hazard, especially the ones you mount from the side.
Edited by WF owner - 21 Aug 2026 at 4:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2026 at 8:06pm
One more time: Allis-Chalmers Farm Equipment Division NEVER offered or MADE any right hand steps for a 180/185 tractor. Did short line companies or private businesses make any?? ..YUP, but not Allis-Chalmers !!
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2026 at 10:48am
A retired LA county fireman had many stories of the person being responsive at their arrival, but as pressure is removed it is over.
Look out for tractors they are dangerous if you don't give them the respect they deserve. An older fellow here with numerous AC, IH, and Cat small crawlers roll started them as it took to many batteries and everything is a hill here. Got pitched off, with tractor or pulled equipment still on him when found.
What was on the safety decals on 1950's equipment "Safety First It Never Hurts".
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2026 at 5:55pm
We're getting off-topic here and I apologize for that, but I just shudder when I see somebody standing on the step of a moving tractor (often kids) and I seem to see this most often at tractor shows.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2026 at 10:53pm
Machines are dangerous. Everyone knows that but gets complacent. Only takes one mistake. Even when you are being carefull,machines are dangerous. Soooo many ways to get hurt.... or worse.
