6080 after market radiator suggestions
ssefick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Topic: 6080 after market radiator suggestions
    Posted: 20 Jul 2026 at 7:54pm
Hi all.
I have the radiator at off and at the shop. It is pretty beat up and rusty.
The fellow suggested I might look for a new radiator in case it is more cost effective.
Anyone have any suggestions? Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2026 at 8:12pm
Call an AGCO dealership and ask if a new one is available anymore and if so, how many $$$$$  ???    My guess is new ones aren't available, so recore yours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2026 at 8:09am
They discontinued the radiator, unfortunately.
Yeah, looks like a recore is going to have to happen.
Thanks for the help!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2026 at 2:45pm
Nothing wrong with recores.  I do that with all of mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2026 at 3:23pm
I'm good with it. Radiator fellow is a little worried about the rust.
We'll see what he finds out.
Thanks again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2026 at 8:35am
After cleaning the radiator the bottom tank is good and rusted.The shops I've been to are hesitant to deal with that tank. I found a radiator builder, but it's aluminum for race cars. $$$...
Agco stopped making the radiator. I am having a hard time finding after market.
Any ideas for looking for a salvage one?
Maybe something else I'm not thinking of?
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2026 at 9:38am
I dont know if one off of a F2 combine is the same.
Have no idea who you contacted but i found Griffin performance radiators. It would be aluminum but thats probably all you can get nowdays. As long as it keeps it cool i dont see how it matters what its made of
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2026 at 9:43am
Everything has gone up termendously. About 5 years i had one recored for s 8070. 1400.00. Had another recored for another 8070 about a month ago. 2600.00. Almost double
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2026 at 5:26pm
Took mine to my local shop- they sent it to a place in Texas, completely redone  was 550- but was 6 years ago
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2026 at 7:19pm
Any ideas on salvage yards?
Maybe an industrial radiator place?
I'm going to send griffin a picture tomorrow. I found a racecar radiator guy the other day that could probably build one.
Unfortunately, I'll pretty much day the $$$s because it's my tractor, and I use it.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2026 at 8:56pm
Combine rad would not fit on a tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2026 at 9:21pm
Combine radiators will not fit a tractor. A 6060 or 6070 radiator will fit, but I'd have to research if they are the same p/n or not. Core thickness (cooling capacity) would be the only difference.  EDIT: All three tractors have a different p/n for their radiator. They will fit, but cooling capacity is reduced on smaller rated HP engines.
Edited by DrAllis - 24 Jul 2026 at 10:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2026 at 7:17pm
Shoot! Thanks for looking.
I have some leads on a tank fabrication, but still looking for a salvage if I can.
Will aluminum be too brittle? Will it break in a tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2026 at 12:44pm
There are millions and millions of aluminum radiators running up and down the hiways that apparently don't have a problem. I think that it is not a matter of being made out of aluminum....it
is a matter of do they do quality work. Your 6080 radiator is mounted on four rubber isolators. If it is a quality build, I sure see no issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2026 at 1:08pm
Great to hear.
Just to make sure I have all the necessary parts in case the radiator has been removed prior to me.
There are 2 circular rubber bumpers that the studs slide through.
Are there other parts that go under the radiator that isolates it from the frame plate steel?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2026 at 6:31pm
Two on each side .
