4 bottom 16 verses 4 bottom 14
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: 4 bottom 16 verses 4 bottom 14
    Posted: 28 Jun 2026 at 9:39pm
how much differance would their be in the two differant size pulling them  i am thinking a bout takeing two rollover plows and making a mounted four bottom with a tail wheel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2026 at 9:47pm
My math says 4 x 14's takes 56 HP to pull and 4 x 16's takes 64 HP. That also translates into a minimum weight of 5600 lb and 6400 lbs. This has been a formula I have used for years. Your results may vary with different soil types and the lay of the land.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2026 at 11:40pm
Wouldn’t it be cheaper, by the time it’s all said and done, to just buy a 4x16 plow? They sure don’t bring much at auctions these days.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2026 at 8:17am
frieght from the  mid west  ?   thats the game changer
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2026 at 9:03am
If freight is a problem and time is not you might get a shipper to combine a load headed in your direction so everybody pays less. I did that one time. Luke in Wisconsin had a 7 bottom 3000 plow he had painted and put new tires on. It looked brand new. I had fantasized about one of those since i was a boy. I called him and asked if i paid him for it could he keep it until i could get it picked up. He said yes. I called a shipper i knew that worked the midwest a lot and he said let him work out a load and it wont cost that much. I think it was about a fourth of what it would have cost. May help may not your results wil varry
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
