AC 1300 FC wheel hub
dnel45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Topic: AC 1300 FC wheel hub
    Posted: 13 Jun 2026 at 7:29am
Had a bearing go out and it trashed the hub out pretty good, cleaned it up but new bearings are sloppy in it. Anyone have a good used hub around? Agco wants $589 for one.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2026 at 7:31am
I might have a couple from a 1200, likely the same. Will look today.
Edit; Since I have developed the habit of posting and forgetting, put my shoes on and went for a walk. I do have one, missing the bearing cap but they aren't hard to find. Took a couple pictures, call/text me, 641-521-3575, Mike.
Edited by IBWD MIke - 13 Jun 2026 at 7:40am
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2026 at 8:01am
Can you peen the hub to get you going??  I have done that to hubs if not too badly worn! May help for a while.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2026 at 3:23pm
Look into generic wagon hubs. AC wasn't one to design a specific part if something off the shelf would suit.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2026 at 8:22pm
I have some
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2026 at 8:43pm
Hey Mike thanks for checking - is it a 6 bolt hub?
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2026 at 9:50am
No, mine are 4-bolt.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2026 at 7:11am
dNel45, try using a sharp center punch to divot the hub’s inner housing. Punch ever 1/2 inch inside the hub’s bearing housing to decrease its inner diameter, then press in new bearing races.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2026 at 7:53am
Yes exactly what I suggested. Also Permatex has a race retaining product that helps. I have used it. Will try to get a picture for you. Have some in shop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2026 at 7:19pm
Center punch and red loctite works pretty good.
