Final drive seals contact cement
Dobry Den Chip View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dobry Den Chip Quote  Post ReplyReply Direct Link To This Post Topic: Final drive seals contact cement
    Posted: 08 Jun 2026 at 10:35am
Service manual calls for contact cement under rubber boot and between some of the seals.  Can someone provide a good product to use?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2026 at 11:49am
Is this an oil related seal ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dobry Den Chip Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2026 at 1:48pm
yes. final drive seals, boot and follower assembly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2026 at 3:59pm
I use 3M8001 yellow weather strip adhesive. They also have a black product that is the same thing but I don't have the number for it. Auto Zone has it. Brake kleen off and air dry all surfaces this glue is expected to adhere to. I think it will work for you. I've used it for 50 years on valve cover gaskets, which have oil sprayed on them all the time.
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2026 at 9:34pm
IIRC someone mentioned GM weatherstrip cement for this
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2026 at 8:29pm
Several years ago someone on this site recommended 3M #847 Nitrile High Performance Rubber and Gasket Adhesive; I used it on the final drive seals of an HD5G, so far no problems
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2026 at 10:16am
Loctite 380. We are using it on the front idler seals on an HD6.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
