Tractor seat cushion replacement
AveryD12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Topic: Tractor seat cushion replacement
    Posted: 04 Jun 2026 at 10:16am
Replacement seat cushions are available with wood or steel backing. What are pros and cons. I understand if a tractor is not “shedded” and left outside all the time the wood backing will deteriorate faster than the steel. If the tractor is kept under a shed/barn would the wood backing serve just as well as the steel. Thoughts…opinions appreciated.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2026 at 10:27am
If under cover the wood would be fine. However I went with the metal on my XT and it is under a shed. Definitely holds up better.
rick ky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rick ky Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2026 at 8:09pm
the old seats were bonded on the d17. no seams to take on water and soak the foam. i have a two pc. black and white on d17 and it took on water the first day due to the seams. put a 3 piece like on 190. it takes takes on water at the seams. i flip the seats onto steering wheel to reduce water in the seats. i will be having them recovered hopefully with one each on seat and back.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2026 at 8:48pm
dont buy awood backed i dont think any of the materials used are as good as the the metal backed ones i use saddle soap  on all my seats  vynal and plastic tractors four wheelers snowmobiles keeps that stuffin good shape heelps keep the sticthing in good shape
