Tires for my 200 radial or bias
Ilikeallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ilikeallis Quote  Post ReplyReply Direct Link To This Post Topic: Tires for my 200 radial or bias
    Posted: 10 Nov 2021 at 7:21pm
I have 18.4 - 34 on my 200 I have a  JD 710 5 shank chisel plow I do around 45 acres, I had a 5 shank mounted and had now problem, my tires are bad 1 half and 1 wore out, spinnind a lot, tractor has wheel wieghts, was at my local tire dealer where I get all my tire always have, A set of Titan bias like i have my 185 i like em, are 850 a piece mounted and BKT radials are 1100 a piece mounted, are they that much better, back when we use to farm a lot of land we had radials on a 7040, but thats what it came with, i guess my question are the worth the difference, I know everbody has there favorites but this what i am looking at, thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2021 at 7:35pm
Radials have more traction than bias and that's a fact. Mounted will always pull easier than pull-type especially if the Traction Booster system is functioning.
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2021 at 8:14pm
My thoughts are radial for tillage and road use. Bias for loader work and hills, seems like they are more stable in my opinion on the sidewalls. I am still trying to determine which dry rot quicker. I also think filled tires allows them to flex more and give a bite over just adding weights.
Edited by allisbred - 10 Nov 2021 at 8:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2021 at 8:29pm
You'll only buy once....pony up and get the best you can cause you won't want to do it over.
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2021 at 12:04am
I just put new rears on my 200. Same size as yours. I wanted radials for a smoother ride (hopefully). The only thing my tire guy could get at this time was Firestone EVO performer which I think is right at the top of the line for Firestone. No liquid ballast and went tubeless. Total bill after service call was $2,166.00. More than I wanted to spend but they are really good looking tires with a good deep tread. I was surprised that they are made in USA.
Edited by Ky.Allis - 11 Nov 2021 at 1:33am
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2021 at 1:33pm
According to Norm's book, Radials give you a 5.2% advantage in unplowed ground and 2.9% in disked ground. As tested on an 8070.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2021 at 1:50pm
Be even better if you went to 38's!
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2021 at 8:10pm
Ditto what Steve and Ed said.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ilikeallis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2021 at 8:44pm
yeah I am going to  go with radials. and yeah I wish they were 38s, but there not,   thanks
This page was generated in 0.136 seconds.
