runs full throttle |
Post Reply ![]() |
len b ![]() Bronze Level ![]() ![]() Joined: 05 Jan 2021 Location: creston bc Points: 5 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Jan 2021 at 1:27pm |
Hey guys. I am new to the site so bear with me if i am in the wrong place. Restoring an Allis Chalmers B. it was really really bad when i got it .Engine needed lots of machine work so got lots of money in it .Here is the problem. got the engine rebuilt. Did the carb. On initial startup it runs wide open. double checked the carb to make sure the throttle plate wasn't in backwards. Its fine. Governor looks rather simple but i haven't had much to do with em i am having a hard time figuring out exactly how it works. I realize on throttle centrifugal force spreads the weights. fork under throttle bushes the collar back into the weights to close em. Thing is i don't really know how touchy this stuff is. For sure my weights and pins are a bit sloppy. Also i didn't have the little spring on the lincage that runs down to the carb. On hindsight this piece could be more important than i thought. Also its possible that my governor lincage could be out a tiny bit tho i have since figured out how to adjust it properly i think .I don't mind buying a new governor if it solves the problem but as i live in BC Canada by the time i get it here the damn thing is nearly 300.00.I would just like a second or third opinion before ordering. Sorry about the long winded love letter. Len
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21724 |
The governor weights do not make it idle. Properly adjusted throttle/governor linkage and a properly adjusted carb low idle screw make it idle. With the engine OFF and throttle lever clear back, the throttle plate on the carb should be closed tight against the slow idle screw.
Edited by DrAllis - 06 Jan 2021 at 3:08pm |
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5058 |
Try cheap and simple first, it could very well be that missing spring. I've was hoping that someone that really knew would post.
Dusty
The missing surge spring isn't why it won't idle down.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5044 |
If you have a service manual that you used when doing the overhaul, refer back to the governor section and check the linkage across the front of the motor. You may need to bend the cross arm to get it right. With the engine not running, unhook the rod back to the carburetor, it should be just a bit too short when the hand throttle is in the fastest position.
The governor does its thing to slow the engine when the weights fly outward. The spring on the top of the governor tries to overcome the force of the weights when the hand lever is moved forward. A little looseness isn't a big deal and thing should operate properly if the linkage is adjust correctly. The surge spring isn't really needed if the carburetor is the correct on for a B as the butterfly is relatively small. It was added in later years as the venturi and butterfly became larger.
Post Reply ![]() |
