agco pto |
Post Reply ![]() |
brodersen ![]() Bronze Level ![]() ![]() Joined: 03 Oct 2020 Location: charter oak, ia Points: 35 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Dec 2020 at 10:23am |
My dt160 pto wants to shut itself off , so to restart it i need toshut switch off and restart it but will kick out again. not always though. what could be the problem wiring or inturnal ?
Kansas99 ![]() Orange Level Access ![]() Joined: 26 Feb 2015 Location: W Kansas Points: 4868 |
Probably a dumb question, but do you have right speed selected and the right pto shaft in?
yes` it is on 1000 pto.
i think iot could be the wiring harness, but the shop guy says it could be inside .
frankmi ![]() Silver Level ![]() Joined: 11 Sep 2009 Location: michigan Points: 52 |
Had a GT series AGCO that did same thing, very frustrating, if there isn't any unusual internal sounds and correct oil amount than I would say it is the pto switch! Switch changed and no problems after. Was told there was problems with original switches and new heavier duty switches were replacement!
Is it getting a good speed reading, the reason I asked about pto shaft is if the wrong one is in for selected speed it will run briefly then kick out. There is a sensor that reads the holes in the outer round part of your pto shafts. I think that it's the one you can see on top in back. Maybe these wires are bad or sensor?
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5144 |
Aren't electric and computer controls fantastic---NOT
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8363 |
So very true there,, its just me but , Im in the One Eighty days- some guys worry so much about the tach reading rpm,s - I have learned just listen to the machine , IE, haybine, baler- youll know when its good,
JohnColo ![]() Orange Level ![]() ![]() Joined: 03 Apr 2020 Location: Niwot, CO Points: 1263 |
The problem is you would need something like 4 WD's to match the HP.
That would also take 3 other people off the unemployment line to drive those other 3 WDs. Also look at the compaction problem you wouldn't have with a bunch of 4000 pound tractors instead of on 20,000+ plus one. compaction was never and issue in the years past, before No-Till. Much like the 3500+ head dairy farms that milk round the clock with immigrant labor that have put the "family farm" out of business.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22049 |
The computer on the tractor has to "see" PTO RPM's and it has to match what the engine speed is or it will assume the PTO clutch is slipping and then disengage.
sometimes it will work but running graincart it just shuts off ,then need to shut off pto switch and restart and still wont work doesnt run a minute and do it again. now i wonder if it could be the switch.
Post Reply ![]() |
