Ca disc plow vs wd disc plow? |
Post Reply ![]() |
dr p ![]() Orange Level ![]() Joined: 24 Feb 2019 Location: new york Points: 1396 |
![]() ![]() ![]() ![]() ![]() Posted: 17 May 2020 at 4:41pm |
Picked up a two bottom disc plow this weekend. Pin hitch not snap coupler and not semi mounted. Just went searching for an owners manual on Ebay and it seems like there could be a different plow for the ca and the wd. Anyone got any info ?
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54058 |
Wd's would likely pull a 3 bottom, where the most a CA will do, is 2 bottom...
DennisA (IL) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ridott IL. Points: 2064 |
I had a 2 bottom disc plow with the WD hitch. I pulled it with my CA without any issues. Wish I still had that plow, it was fun.
Thanks & God Bless
Dennis |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21847 |
Never worked on or ran a "CA", but I thought there was something different about the lift arm spread width?? over a WD and larger ?? or maybe the pulling eye/pull bar length ??
You are correct on all counts. However the WD rear mounted equipment will still work on a CA as long as the lift links pivot and have the right hardware. Snap-coupler is the easiest as parts are everywhere. I posted a video of my CA pulling a 3-14 plow. That plow is setup for a WD or WD-45. The CA handled it very well in both pulling and lifting.
Edited by DennisA (IL) - 18 May 2020 at 2:58pm |
Thanks & God Bless
Dennis |
So a ca can pull a disc plow made for a wd but can a wd pull a disc plow made for a ca? Sounds like no.
Any mounted equipment made for a CA will not work on a WD do to the shorter hitch on the implement.
Thanks & God Bless
Dennis |
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3078 |
The difference in the hitch as far as the tongue on a plow I've seen is the bolt on piece that goes into the snap coupler is longer on a WD/D 14 series etc than on a CA,D10/12 the basic tongue is the same just swap pieces.Believe I remember some of the end pieces actually had two sets of holes for either.
The pull bars for the CA are different than the pull bars for the WD.
Thanks & God Bless
Dennis |
Main reason a CA won't handle a 3 bottom disc-plow, is the weight, if you do manage to hook it up, the lift lever will just lift the front end of the CA!
Now you got me thinking Dave! I have a 3 bottom disc plow that I replaced the discs on. I’ve never hooked up to it yet. I’ll try the CA and see how it lifts it. They are heavy. I highly doubt the CA can pull a 3 bottom disc plow as a 2 bottom works it pretty good, but I just got to try!
Thanks & God Bless
Dennis |
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
Now you got me thinking Dave! I have a 3 bottom disc plow that I replaced the discs on. I’ve never hooked up to it yet. I’ll try the CA and see how it lifts it. They are heavy. I highly doubt the CA can pull a 3 bottom disc plow as a 2 bottom works it pretty good, but I just got to try! [/QUOTE] Video please!
Turns out it is a model. Wd d serial number 678 made by Athens. Need to figure out how to mount center link
Can you post a picture?
Thanks & God Bless
Dennis |
Post Reply ![]() |
