G230 engine spark plugs
chuck (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck (WI) Quote  Post ReplyReply Direct Link To This Post Topic: G230 engine spark plugs
    Posted: 15 Oct 2019 at 11:00pm
Picked up a g230 engine out of a combine and can't seem to find what the correct spark plugs this engine used, any advice would be helpful.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2019 at 7:02am
AC Delco 45XL
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2019 at 7:08am
Early AC45, later AC45XL, depends on thread length in head.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2019 at 4:21pm
It's a latter engine, thanks for the info.
MeThInK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MeThInK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2019 at 2:19pm
Chuck,
I have a Gleaner A2 (AII) with the 230 engine.  Just checked my plugs and they're Autolite 405.
Mike
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2019 at 3:18pm
the AC plugs work the best
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2019 at 7:35am
Thanks, mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote MeThInK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2019 at 9:48am
Mack,
Thanks. Looks like AC45XL are not available in my searches. Though I find R45XLS.  Still looking though.
Question: I see the manual specifies 25 gap but most of the plugs come 35.  Should I gap it down to manual or leave it? Thoughts?
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2019 at 9:57am
  .025" is what the ignition system was designed for.   .035" is for more modern higher voltage systems.  R45XL or R45XLS will work.
Edited by DrAllis - 19 Nov 2019 at 9:57am
