1953 CA wide front end?
Hunt4Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Topic: 1953 CA wide front end?
    Posted: 10 Jul 2019 at 11:55pm
I'm going to be switching out my narrow front end for a wide front end and I've been told that the easiest way to change the front bolster is by removing the radiator which if im going to do that I'm going to drain flush and change the radiator fluid while I'm at it so that I have peace of mind that it's in good working order, anybody have experience with doing this and needing to remove the radiator?
Edited by Hunt4Allis - 10 Jul 2019 at 11:56pm
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 5:51am
That would be the way! After it is stripped bare in the front you only have the four studs to slide the bolster off and slide the other one back on the studs. I have always done it by myself but it would be prudent to have help. It is heavy and floppy even with an engine lift and floor jacks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 5:57am
Hmmm, don't have engine lift or multiple floor Jack's( I just figured on using a long sling under and up to trusses I trust for the load)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 11:48am
You could still make that work with blocking to crib up to the levels needed to get the wishbone to line up as you slide the bolster over the studs.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 12:13pm
I just block under the torque tube and use a cherry picker
This page was generated in 0.035 seconds.
