Oil capacity 7010
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Topic: Oil capacity 7010
    Posted: 18 May 2019 at 12:44pm
Book says 16 quart 7010,16 quart 8010. I put 12 quart in and it's at full. Tractor has a combine engine transplant. Combines took less?
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 12:51pm
Was it full when you changed the oil did you drain 3 gallons out or 4 gallons out
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 12:58pm
It was in the "run" level not full. I didn't measure it. But the turtle catch pan wasn't close to full. Maybe 2 1/2-3 gal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 3:57pm
When they say 16 quarts that means with two new oil filters being changed at the same time. 14 quarts into the pan and 2 quarts to the filters. Combine transplant ??  WHAT YEAR AND MODEL COMBINE ??   I would certainly trust the dipstick as long as it's the one that came in it from the combine.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 5:05pm
Have no idea on the combine. Engine does have the intake with out the cast in Allis Chalmers script. I did change the filters also. I fired it up,idled for a few minutes to circulate and shut it back down. After that it read right on the "add" mark. That pan is wider and longer as it gets closer to the block. Maybe it will suck up that last gallon. I'm going to trust the dipstick just sneak up on it a quart or two at a time.
Edited by exSW - 18 May 2019 at 5:07pm
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2019 at 10:39pm
Sounds like you may have an older style engine with the cam driven oil pump. Is the oil pan deepest at the front or the center? I think the older engines had a smaller oil capacity. Also the factory engine should have 2 identical full flow oil filters.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 6:29am
I think my 200 takes 15 quarts. I fill the filters up before they go on the engine.
Wink
I am a Russian Bot
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2019 at 12:24pm
Took a look the other day. Center sump oil pan. Tapers up away from sump front and rear.
