200 fan on 190 series 3 |
DCAC
Joined: 20 Oct 2018 Location: east central SD Points: 529 |
Topic: 200 fan on 190 series 3Posted: 30 Apr 2019 at 6:44pm |
Aside from it being a little larger in dimeter, are there any negative effects of swapping the 200 fan in for the 190 fan?
DCAC
Posted: 30 Apr 2019 at 6:45pm |
should read diameter, not dimeter, sorry!
DougG
Posted: 30 Apr 2019 at 7:42pm |
Shouldn't be , I think the 200 has 7 blades for drawing more air in
DanWi
Posted: 30 Apr 2019 at 9:12pm |
Part of that swap would be double fan belts. You have to keep the single belt tight with the old fan to keep it from slipping. You would need crank pulley with two grooves and alternator pulley.
DrAllis
Posted: 01 May 2019 at 7:00am |
Two belts or don't do it !!!
DCAC
Posted: 01 May 2019 at 7:11am |
Thank you everyone for all the help and advice on this!! I would have never thought of everything that's involved with making this modification, and would have had to learn the hard way...again!
Alvin M
Posted: 01 May 2019 at 8:24am |
mine crank pulley had two groves changedwater pump pulley and alternator pulley used two belts and fan same as 200 it ran much cooler had 125 hp
