D15 Governor Leaking |
BrianC,Ont
Joined: 11 Sep 2009 Location: Belleville Ont Points: 903 |
Topic: D15 Governor LeakingPosted: 30 Apr 2019 at 1:42pm |
The governor on my D15 and my I600 forklift are both leaking where the shaft comes out of the housing. It looks like the shaft is welded to the fork.
Thanks. Brian |
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
MACK
Posted: 30 Apr 2019 at 10:13pm |
I thought they were supposed to leak there, they all do. lol MACK
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25314 |
Posted: 01 May 2019 at 6:04am |
I have to think maybe there's a rollpin holding it in. Manual says it's an 'assembly', so not designed to be tore apart and rebuilt. All 3 of my D-14s 'weep' so it's normal to me too ! If (IF...) there's enough space , you could cut an Oring,put on shaft, then glue the Oring back together. There's a special glue for that, Oring supplier gave me some 40 year ago, and no, I have NO idea where it is.. Ideally it should be resealed from the inside though. I could tear aprt my running parts D-14 but have a few raindrops to deal with here..... Jay
BrianC,Ont
Posted: 02 May 2019 at 9:09pm |
There is no rollpin, the shaft is welded to the fork. My dealer still lists the part # for a housing for $520.
MACK
Posted: 02 May 2019 at 9:12pm |
That would buy a lot of oil and car washes. MACK
BrianC,Ont
Posted: 02 May 2019 at 9:28pm |
If it was just a trickle I would leave it. The I600 didnt leak,because it had very little oil pressure. The D15 puller leaked enough to be a little annoying. When the head gasket went in the forklift I put the motor out of the D15 in it and used the I600 governor housing.Oil is leaking so bad that the fan just blows it everywhere.
