adapt and improvise |
Post Reply ![]() |
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8721 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Feb 2019 at 7:01pm |
![]() Here is how I run a three function loader (lift, bucket, and grapple fork) with two hydraulic remotes on my XT. The first hydraulic remote just runs the loader up/down function normally. The second hydraulic remote, which as you can see, I have modified the lever, runs both the bucket function and the grapple fork. I run the hoses from the second remote into an electro-hydraulic valve multiplier; one set of hoses in; two sets out. Basically how it works is this. The modified handle (which you may recognize as the top of a hydro handle off of a gleaner combine) has that rocker switch in it that is easily operated by my thumb. If I depress the top of the rocker switch, the bucket is operated when I use that hydraulic lever, and the grapple fork is operated if I depress the bottom of the switch and use the same lever. I know that I did not re-invent the wheel here, and electric button/switches have operated grapple forks for years now. But one thing that I do like about this over new fangled grapple buttons, is that I can still feather the grapple fork with system. The newer ones are either stopped when the button is not pushed, or full blast when the button is activated. So far, I like it. Darrel |
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8455 |
Nice!! I like it!
Unit3 ![]() Orange Level ![]() ![]() Joined: 17 Oct 2009 Location: NC Iowa Points: 5603 |
YOU ARE THE MAN!!! Now come down here to Iowa and put my N7 hydro handle in my 7045 as a side mount throttle lever handle on the console's side. (like it should have been in the first place) Then I can use the switch to turn on and off my sprayer.
What size tractor?
And do you have any new cows to show us?
shameless dude ![]() Orange Level ![]() ![]() Joined: 10 Apr 2017 Location: east NE Points: 13607 |
good job buddy!
B26240 ![]() Orange Level ![]() Joined: 21 Nov 2009 Location: mn Points: 3866 |
Farmer inginuity
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54283 |
Back when I had the jeep, with a v plow on the front, I bodged up a rear plow, for the back... Did something similar, routed a notch for a push button switch, for its controls, in the cable end. That thing was just plain ole fun, in the snow, and with a plow at either end, no matter how you skidded, alls you hadda do was shift directions, drop the front plow, and lift the rear facing one, and mash down on the gas pedal... Dam shame the motor was wore out...
Not calving yet. But I suppose since we supposed to get 10 feet of snow today, they'll start calving. Darrel |
Cracked window sure sticks out like a sore thumb in my picture. I best replace that. Darrel
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8648 |
Well I want to know how it is that you posted a photo and I can't believe no one else mentioned it!!!! Now we will expect pics of all you projects!
I have not put up pics since the Photobucket mess and don't care enough to learn a new thing.
My son posted it for me. I have no idea how he did it. darrel |
farmboy520 ![]() Orange Level Access ![]() ![]() Joined: 22 Jun 2016 Location: Beason, IL Points: 553 |
I didn't think anything of the broken window darrel, you've been busy driving and delivering goods to the rural community. We all know that you will replace or fix things when you get the time.
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
Hubert (Ga)engine7 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6493 |
Great farmer ingenuity! I would put repairing that broken glass several notches down on the priority list as long as it is holding together and the weather is terrible.
Post Reply ![]() |
