220 FWA
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: 220 FWA
    Posted: 28 Jan 2019 at 6:42am
Ran across this on FB and thought it was neat
Guy up in Canada has it
Charlie
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2019 at 7:45am
Never seen that kind of cab modification before.  Or, a loader on a Two-Twenty FWA.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2019 at 8:42pm
That would make a snow mover!!! I would like to see the inside of the cab.
A-C_220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-C_220 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 10:02am
That is a good looking tractor even with cab and loader. Any idea where up in Canada?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 10:05am
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 10:07am
trying to get more pictures of it
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 10:09am
Here is the other one before I shrank it
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 10:09am
Is there more fwa out there then recorded. Seems like Iv seen posts on how rare they are but seems like a lot randomly show up on forum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-C_220 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 10:26am
Wow does that hour meter have only 1300 hours on it!
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 11:12am
Absolutely Mike. Way to many show up. There are several you know have been scrapped, several you will never know about. And they say there were only 100 made. I don't believe it. I have seen more 220 fwa then 4w220s. And there were only 175 of those made, 20 years later.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 11:28am
I like it, but I got a different question. Why is the cylinders installed with the rod end down? For speed or to lower the lift capacity to keep from destroying the loader? There is 3 at home and not one is like that. Just wondering
waldersha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote waldersha Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 1:18pm
My guess is because it has hard lines on the inside of the right side arm that run to the front, short hose from there to the cylinders.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 1:26pm
Interesting theory.....Isn't that kind of like saying the meat is in the middle of the sandwich "because" the bread is on the outside?
Meaning, are the cylinders mounted that way "because" it's plumbed that way, or is it plumbed that way because the cylinders are mounted the way they are?
I think the original question of is it designed for a specific function is still valid.  Or are the loader builders in this case just not too smart?
Post Options Post Options   Thanks (0) Thanks(0)   Quote waldersha Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 2:09pm
It makes for a cleaner installation was my point, but your point is received and valid.  I should have taken more time to explain my perspective.
Hard lines are easier to make a clean installation than rubber hoses, so they ran hard lines to the front of the right arm, and short hoses to connect to the cylinder, then crossed over to the left side and did the same thing there.  Probably also cheaper to run hard lines than rubber hoses, not positive on that though.  The alternative (flipping the cylinders) I believe would lead to additional materials (steel or rubber lines) being needed to get down to the connection at the bottom of the loader frame.
I don't believe there is any performance gain or loss by doing it that way, maybe a slight bit because of the extra weight of the cylinder on that end rather than just the rod.
And you put the meat in the middle of your sandwich?!?!Smile
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 2:25pm
Oil seapage will make less mess ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 2:32pm
Well, except for that KFC chicken breast health food thing once in a while!
It's all good.  I understand what you mean.
To the guy who asked the question, it wouldn't reduce the lift force, as extending the cylinders still lifts the loader, it's just a question of which part of the cylinder moves.  I've seen both directions.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 4:26pm
Nice to see another one in Canada. Had a trucker from Sask. stop for a tour in November and he used to own one when he farmed.  Three that I know of in Ontario including mine. All new here with one still with original owner. Have about 45 accounted for. Having just removed a LaPorte cab, there would have been a lot of work installing a 7000 cab. Would still be noisy!
Edited by Calvin Schmidt - 29 Jan 2019 at 4:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-C_220 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 4:45pm
also when it rains instead of having water pool up on top of the seal on the cylinder it will run off.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 5:10pm
Without chains doubt it would be a real stud.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 5:42pm
I like the 7220 FWA, but now I want to see a 8220 FWA.
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 5:55pm
Darryl has the first 220FWA Serial# 2223 and highest 220FWA in the registry  is Oughtred's is serial #2433, a spread of 210 serial #'s.  So they were or were not  continuously built on the line?
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-C_220 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 5:58pm
Oughtred's has headlights on the side of the grill right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 6:05pm
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 6:45pm
Most loaders have the cylinders that way for removal. That way the cylinders stay with the loader. All the plumbing is on the boom and connects in one location typically on the right hand side. The performance would only differ in the weight of the rod vs the Barrell as stated above.
Edited by wekracer - 29 Jan 2019 at 6:46pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 7:11pm
Gord still has his 220 fwd but hasn't had it running since the 2009 GOTO.
I saw 2442 in North Carolina. Looks like A-C made an initial run of 75 or so consecutive serial numbers and then as required after that.  I have 9 consecutive numbers in my registry
Edited by Calvin Schmidt - 29 Jan 2019 at 7:15pm
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 8:25pm
Charlie 175 if you could get the serial number for this tractor i would appreciate it. Thanks
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 10:16pm
Dpower, How many you got recorded now ?
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 10:48pm
Some of the front wheel assists could be after market, such as Mudhogg possibly?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 12:08am
I got what Calvin has for ones with serial numbers. I have pictures of a few that i am trying to get the serial numbers for. Found one the other day that they tried to put a 516 motor in but did not work out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 12:03pm
Dpower an Calvin am I understanding it right. Your keeping track or recording SR nu of fwa 220. That's cool. Did you get get those that popped up over on classifieds
