F2 engine oil
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: F2 engine oil
    Posted: 17 Oct 2018 at 6:11pm
Our F2 has the 433 in it,turbo only. I changed oil and filter today and dumped 15w/40 Shell Rotella oil in it like we have done since we've owned it because that's what the original owner said he ran in it(we are the 2'nd owners). I was browsing in the operators manual for an unrelated querry and stumbled on the oil selection page and found that only a variation of 30 w is required, NOT 15/40 !! Please tell me this won't be an issue??  Thanks
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2018 at 6:22pm
HTH
    B:-       Dnoym
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2018 at 7:49pm
They want 0W-20 in my car. Synthetic only. Reading a little closer in the manual they go on to say that 5W-30 can be used. In most cases you can go up or down one weight. FWIW I have my oil changed at a Ford dealer where they use 5W-20. I have no problem with that.
8070220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070220 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2018 at 7:52pm
Yep only 30 in ac eng if not they will not last I been rebuild eng for 25 yr mostly allis and I tell u when I open one up if it had 30 or that other junk oil .if it ant had 30 in it the oil pump it junk by 3000 hrs .and that 433t it one that good for that .
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2018 at 9:15pm
30 wt is way to thick for the winter startup and just average for summer use.. A GOOD 15 w 40 DIESEL oil will be great.. The 15 is thin enough for good starting and initial lube when the motor is cold... and the 40 wt on the top end gives great lube and high oil pressures when the motor is hot and loaded during summer usage... MANY AC diesels are now running 15w 40 DIESEL oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2018 at 9:18pm
Thank you Steve, that other reply had me worried LOL !! BTW, WOT oil pressure is around 70 ,idle pressure 60.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2018 at 9:29pm
My F2 has 15w40 rotella...for years....
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2018 at 10:38pm
I run 15w40 in my 860 cotton stripper, as did the previous owner. It has the 2800 engine, though, which I don't think is too much different than you 433T, aside from being 6 cylinder. It's going on 43 years and runs great with great oil pressure.
I'd wager my uncles run that oil in their 880 cotton strippers as well. (433I engine).
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2018 at 5:39am
I use 15w-40 in all of diesel engines. That is the way dad did it and everyone else around here does also.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2018 at 8:09pm
I think starting around 1983 Allis started recommending 15w40 in the manuals.
They were slow to approve a new type of oil versus the "old standbys"
That said, I would be more concerned about the Rotella. I have never had much luck with it, seems to be thinner when hot, and burns more.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2018 at 9:12pm
More like 1977 A-C was using 15W-40 from the Factory in all their engines in tractors and combines.  I can think of at least six tractors (6080's) that got 9,000 hrs on them before overhaul was needed and all of them used 15W-40 oil.
ACjack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACjack Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2018 at 9:47am
Not to question you but, in the desire to learn where did the info on what weight oil the factory was using for factory fill in 1977 come from? To the best of my recollection we always used Shell Rotila 30W in every engine that was shipped from Harvey, IL while I was employed (1968 thru 1979) there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2018 at 11:34am
I remember a sticker being applied to the left side frame giving that information. The Owners manuals hadn't been brought up to date on the 15W-40 oil change spec because that required a "reprinting" of each particular tractor model book. They felt the oil viscosity spec change needed to be gotten to the Dealers and the new tractor Owners ASAP.   The combines?? I'm a little fuzzy on that, but one would assume if the tractors had 15W-40 the Combine Division would also?  And maybe there was a similar sticker on the valve cover.....??
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2018 at 9:30pm
Yeah, Doc. AC was hesitant at first to adopt the multi viscosity oil, but quickly came on board with pushing the 15-40 for example when everything improved with its use after they started testing the oil the suppliers were providing to the parts dept....
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACjack Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2018 at 8:56am
No engine left Harvey with any kind of a sticker or decal dealing with what kind of oil is in it. It's quite possiable that once the tractor was built and shipped to a dealer the dealer made an oil change and added a decal/sticker advising the change in oil. That could explain the different mounting locations for the decal/sticker.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2018 at 9:14am
All allis  diesel tractors  in 1980 and up had a sticker on left frame at rear NOT to use multi viscosity oil in engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACjack Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2018 at 10:31am
Makes sense to me seeing that I left AC at the end of December 1979.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2018 at 6:48pm
Well, that's nice to know that since 1980 I've been doing it all wrong. !5W-40 is a Multi-Viscosity oil specifically made for DIESEL ENGINES and the only oil of that type at that time that I am aware of. I've never seen this decal/sticker you are referring to, and I worked for A-C in 1980 and 81.  Is there any chance this sticker was trying to make reference to not using multi-viscosity oils made for a car/gasoline engines??  because that would be true.
nick121 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2018 at 9:15am
I run 15w40 rotella in my Allis diesels, no problem what so ever. Not sure why you guys are thinking 15w40 is bad for them.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2018 at 1:14pm
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2018 at 2:04pm
Yeah, but still....
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2018 at 2:38pm
BLESS YOU, RON (AB) !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACjack Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2018 at 5:15pm
The picture of the decal clears up a whole lot of confusion.
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2018 at 12:56pm
If you look in AGCOs parts book for the 8000 series that decal is in the decal section. Page 176 for the 8030.
Life is simpler when you plow around the stump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2018 at 1:22pm
I'ved used Rotella 15w40, during the summer, in everything I have over about 25 years old diesel or gas.
1951 B
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2018 at 4:34pm
That decal is on my dads 185 too.
DavidnTenIll View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidnTenIll Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2018 at 5:18pm
Shell Rotella 15w40 does not meet specs for DD 2-71. Ash content to high. Also does not meet requirement for IH 706 gas engines and is probably not good for older Allis gas or diesel engines. CIH specifically sells there Akcela low ash oils for their older engines. Also zinc content is low for older engines. Newer oils are blended for newer engines and bearing technologies have changed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2018 at 10:36pm
Back in the day,DDA recommended straight 30wt in the two strokes.Later 40wt.No multigrades. I think all multi's are too high in ash content.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 7:24am
Detroit Diesel (2-stroke) is an entirely different animal from any other diesel. What you say is true, but irrelevant to the topic.
Edited by TramwayGuy - 27 Oct 2018 at 7:24am
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidnTenIll Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 6:12pm
Shell makes a T1 product in straight 30 and 40w that is recommended by them for DD and "other older diesel engines" ( their words not mine) The removal of lead from gas and sulphur from diesel fuel is also a problem for older gas and diesel engines. You work those engines hard like they were at one time and it I contend it is a problem. IH 706 and 806 gas engines had definate problem burning valves with high ash oil.Most modern oils don't spec out very well in those categories and also have low zinc content. Much of that is driven by pollution control by gov., not necessarily the quality of a lubricant.
This page was generated in 0.123 seconds.
