Allis Forklift
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: Allis Forklift
    Posted: 26 Nov 2017 at 6:01pm
Thought I would post this here also.I am looking at an Allis forklift that has a bad motor. I cant seem to find much info on it. Hopefully someone can tell me where to search. It is a model ACP 50 DSPSSNLG Serial # AJK 132252. Was wondering what motor it would have in it, and if parts are still available. It runs on propane.
Thanks Brian
https://www.kijiji.ca/v-heavy-equipment-machinery/belleville/fork-lift-best-offer/1313775203?enableSearchNavigationFlag=true
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
theropod View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote theropod Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2017 at 6:16pm
Thanks Brian
A quick Google search turns up a  F160 continental engine.
Put the bunny back in the box!
1938 B, 1977 Yanmar YM2200
No private messages:
use email:
theropod AT yahoo DOT com
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2017 at 7:00pm
What site was that on. I have done google searches and cant find that info anywhere.
Thanks Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote theropod Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2017 at 7:18pm
Thanks Brian
A forestry forum.
use email:
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2017 at 8:42pm
I have an ACP-60H with a Continental F245 flat head 6 cyl. that runs on gasoline. I rebuilt the engine, parts for the engine shouldn't be a problem. Mine had dual hard rubber tires that I removed and replaced with pneumatic. Good 6000 pound capacity machine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2017 at 11:19pm
I will have a better look tomorrow. That guy in the forestry forum must have a F162. I cant find any info on F160 engine.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2017 at 5:56am
We have an ACC 50 (solid tires)in our shop and is a great little forklift. Engine parts should not be a problem. Paid $1500 about 7 years ago.
pabob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pabob Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2017 at 7:49am
Not trying to hyjack this post...but I have a 153 AC for sale.    Came from a rebuild shop and has been completely done over.   Pretty sure these were used in fork trucks.   Thought I would use in an I-600 needing a re-power but too many other projects.   Have pics available
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2017 at 9:53am
I found out it is a Perkins. Not sure what size yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2017 at 9:56am
yeesh Perkins... WHY does that sound 'pricey to fix' ?
marion View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marion Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2017 at 4:54pm
did perkins make a propane engine, or gasoline?
I have fork truck identical to unit you are looking at, including side shift
am sure mine is continental engine. have had it for about 10 years and never had to do anything engine related so have not had to research motor specs. mine is propane also.
I have original service manuel, it has motor options in it, pm me if I need to dig it out and look.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2017 at 4:56pm
PABOB.  A 153 engine is a Buda design and will only work ( I think) in your I 600 if it was originally a diesel which is a Buda design 175 cu.in. Completly different than the 160 gas normally found in an I 600
Post Options Post Options   Thanks (0) Thanks(0)   Quote pabob Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2017 at 5:13pm
Yes. I knew it was a different motor but completely rebuilt and it wouldn't be too hard to adapt it the I-600.   Just not time for the project
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2017 at 8:11am
If you could look that up for me that would be great.
This page was generated in 0.273 seconds.
