Combine Auger pivot rebuild
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Topic: Combine Auger pivot rebuild
    Posted: 05 Oct 2017 at 6:19am
Any tips on rebuilding the pivot on a hydraulic auger rebuild?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2017 at 6:34am
What part are you rebuilding?   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2017 at 12:46pm
The pivot point on the unloading auger. Where it swivels to raise and lower it. It looks like a big ball bearing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2017 at 12:58pm
Just buy a new one. It's called the "swivel".
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2017 at 2:10pm
I'll follow this thread. It seems interesting.
Are you rebuilding/replacing it because your auger fell off? I've had several guys tell me that happened to them.
Edited by CrestonM - 05 Oct 2017 at 2:12pm
Meanolallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meanolallis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2017 at 7:32pm
Mine has the same issue and the auger is half off right now. I think it was messed up a bit when I got it. The tracks filled up with bean dust, dirt, rust, and some ice. The balls started falling out and the auger started working its way off. Like the doctor said, buying a new one will fix it, but I'm hoping I can clean it up and put it back together with new balls to save $800. Here are a few other threads:
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2017 at 8:14pm
That first article says the swivel relies on grain dust to lubricate it. Can that really be true??
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2017 at 8:53pm
When you finish at end of season, oil the balls with ATF or other thin oil so the balls and races don't rust during the year. Run auger out and in a few times to get it all oiled.      MACK
fastallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fastallis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2017 at 3:45pm
I just put 13mm balls in mine. I bought them off ebay. 125 of them. I have to put the auger back on the machine and see how it works. The thing is WAY tighter than before.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2017 at 3:55pm
BUT, the ball track is worn in a couple of spots, so it isn't really fixed like new. Also, there is to be one empty ball space showing when assembled.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2017 at 8:45am
If its available, buy a nylon swivel from Sloans Express. Nylons strips replace ball bearing design. When replacing swivel, place new swivel into a deep freezer for an hour or so before assembly. The cold shrinks the swivel so it easily slides into auger tubing. For lubrication, drill 3 equally spaced zerk holes on outer face (meaning auger is in transport position) near nylon track area. Grease these everytime you grease universal joint & bin shaft journal. Like others say, clean it out, grease it, & operate it a few times before storing it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fastallis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2017 at 8:42am
I got the auger back on the machine after the new 13mm ball install. Although it is not new. It is usable and will probably be good for many years as long I keep it lubed up. I think I paid $36 for the balls.
