Buying Roosa Master bolts |
McGatha185
Topic: Buying Roosa Master boltsPosted: 02 Jul 2017 at 5:03pm |
I need to know where I can buy a new set of banjo bolts for my Roosa-Master injection pump. Mine's got some boogered up threads on a couple of them. It's on a 1970 185 Allis and it's a Roosa-Master DBGFC-637-34FW pump. I've searched the internet and I'm just not finding what I need, but I know there has to be companies out there selling replacement parts for these. I'd prefer new ones.
Thanks for the help!!
Clay
Joined: 11 Sep 2009 Location: Udall, Kansas Points: 10172 |
Posted: 02 Jul 2017 at 7:47pm |
I ordered some banjo bolts from a diesel repair shop. Most any of them should be able to get them for you.
ALWAYS use new special sealing washers under the bolt and the pump. Many equipment dealers should have these washers on hand. I highly recommend you replace both washers on each line. The bolts require a 9/16 box end or socket. They are fine thread. Start them by hand when replacing the bolts, to avoid cross threading. The torque is around 35 ft. pounds.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8765 |
Posted: 02 Jul 2017 at 9:40pm |
and that 35lbs feels like it aint going to get there....scary!
DrAllis
Posted: 03 Jul 2017 at 7:13am |
When installing banjo bolts, leave the mounting stud nuts loose on the pump so it can wiggle around a little and do NOT tighten ANY banjo bolts until all six banjo bolts are threaded in by hand with some WD40 on the threads.
DougG
Posted: 03 Jul 2017 at 11:50am |
I always draw them up tight, loosen, then retighten gets everything where it needs to be
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1531 |
Posted: 03 Jul 2017 at 1:04pm |
Deleted. Edited by Ed (Ont) - 04 Jul 2017 at 12:12am |
DrAllis
Thanks(1)
Posted: 03 Jul 2017 at 2:22pm |
Well, that's news to me. I always thought those bolts were special from Stanadyne/Roosa Master and that was thee only place they could be had.
