B restoring
Dave Wisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Wisc. Quote  Post ReplyReply Direct Link To This Post Topic: B restoring
    Posted: 22 Mar 2017 at 1:07pm
Made a big mistake on the restoration of my B. I did not plan on doing this much of a restore of it at this time , but I am going to. Problem is I am cleaning the engine so question is if I clean the engine with gas and air dry it can I just prime over this or spray it with something else. Thanks Dave
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2017 at 1:10pm
Use a prepping solvent to clean it before you prime it.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2017 at 2:31pm
The paint will most likely peal in a year or so. After cleaning you will need to rough it up to get the paint to bond.   After roughing it up you should wipe it down with grease and wax remover. Paint thinner will work most of the time.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2017 at 2:34pm
This discussion is way over my head.
However, I hope you listen closely to the experts.  I am looking to see another of my favorites restored.
Good Luck!
Bill Long
