Wd power adders
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Topic: Wd power adders
    Posted: 18 Sep 2016 at 7:40pm
So I've got a wd that I'm parting out. I've got a good running engine in it. Dad has a wd45 that the motor is junk in. So my thoughts were to swap motors. It will fit I know but what can I do to a wd motor to pep up the power some without totally reinventing the wheel so to speak
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 7:51pm
Use the manifold, carburetor and air cleaner from the WD-45. That's about it.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 7:57am
Not much unless you're going to put a 45 crank in it. At that point, you might as well rebuild the 45 motor.
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 8:48am
What's different about the air cleaners?
The mechanic always wins.
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 8:50am
the port to the carburetor is larger.
Tcmtech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 9:11am
I just did a full valve train job on a old 9N Ford and while I was in there I did a quick intake and exhaust port cleanup and match. Basic deburring and radius work plus opening up and matching the ports to the gaskets. Same with the manifold intake runners and face.
Even on a old low RPM low compression tractor getting more air through the system with less restriction helps pick some power and efficiency up and it's largely  nothing but a time expenditure to do a bit of port cleanup work.
When you only have around 22 HP to work with (in your case ~30?) adding another 1 - 3 is still a measurable percentage increase! Wink
Edited by Tcmtech - 19 Sep 2016 at 7:58pm
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 9:37am
If you can find a set of them a set of M&W pistons will wake it up a lot. Our WD is stock other then the M&Ws and runs 43-45HP on most show dynos.
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 4:13pm
I plan to put a set of nos AC 6.6:1 ratio Pistons in my WD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 7:57pm
editor mistake. Confused
Edited by Tcmtech - 19 Sep 2016 at 7:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 8:01pm
If the crank is good on the 45, bolt it in with the flat top WD pistons. That will wake it up Wink
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 1:07am
If you use the 45 crank and the flat top pistons, use spark plugs for a Leroi D226 engine, or the pistons will hit the spark plugs.
