D17 Series 2 Muffler?
 Rating: Topic Rating: 1 Votes, Average 3.00  Topic Search Topic Search  Topic Options Topic Options
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series 2 Muffler?
    Posted: 25 Jul 2016 at 6:59pm
What should a D17 series 2 have for a muffler?  I've seen the skirted style like a WD, and a round clamp style like the cheap farm store replacements.  I really need a new one but am not sure which one is correct.  By the parts book with a serial number of 33xxx it should be a 70234494.  I don't see a diagram for how that muffler attaches to the manifold/tractor.
AaronSEIA
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2016 at 7:07pm
The series II uses the cylindrical muffler with a skirt at the bottom with 2 holes in it.  AGCO carries them - they are the real Nelson muffler too (for a price).
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2016 at 7:19pm
That would be the same as the series 1, but the parts book shows a split at 32,000 and a different muffler but no picture of it.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2016 at 7:37pm
Series 2 gas mufflers are round yes, but are LARGER in diameter and have a larger hole in the hood. The mounting method is different too, as I think they had gone to the threaded pipe in the manifold with the larger muffler using a muffler clamp. They were trying to reduce the noise levels of the original Nelson muffler with this change.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2016 at 7:38pm
I think the only different muffler was the oval mufflers that they switched to for the Series III and IV models.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2016 at 7:42pm
Oops, I stand corrected.  Dr. Allis would be correct.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2016 at 7:50pm
I hate to hijack your post Aaron but I have a very similar question. What would be the correct muffler for a Series IV gas?? Thanks guys, Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2016 at 7:52pm
Hmm. Not sure my manifold has threads on the inside. What size pipe did they use and what threads would it be?
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2016 at 7:54pm
Series 4 would be the oval one. I think the inlet and outlet were offset.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2016 at 8:04pm
Series 3 and 4 are oval mufflers, again for a quieter running tractor.
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2016 at 9:25pm
If you find a source for the right one let me know.  I'm looking for a good one for my series 2 D-17.
Life is simpler when you plow around the stump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2016 at 9:59pm
Correct series 2 gas muffler is 4 inches to 4 1/2 inches in diameter. Old Nelsons were about 3 inches diameter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2016 at 10:52pm
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2016 at 3:23pm
Just got this for my WD45 engine im building.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2016 at 3:46pm
That would be for all WD-45 and early generation D-17's.
Brian Ahart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Ahart Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2016 at 4:13pm
The larger diameter straight-through muffler for the D17 Series II (70234494) is still available through Nelson.  The Nelson part number is 06923T.  Check out seller "nelsonglobalproducts" on eBay.  I bought one a few months ago just to have one in stock.
http://www.ebay.com/itm/70234494-AGCO-VERTICAL-TRACTOR-Muffler-06923T-by-Nelson-Global-Products-/272256504861?
A-C Weight ID reference and other goodies at brianahart.net
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2016 at 8:54am
this gives a good clear side by side dimension comparison between series 1 and series 2.                http://www.stanleymuffler.com/catalog/Fall2011.aspx#/6/
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2016 at 10:56am
Brian, does that current Nelson muffler have the same Nelson sound everyone is after? I see OK Tractors sells the correct series 2 muffler (or at least dimensionally accurate) and also has some kind of pipe adapter. Looks like it just slides into the manifold as opposed the threading in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Ahart Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2016 at 10:23pm
Aaron, I have not installed the muffler, so I cannot testify as to the sound.  It does have the perforated interior as with other Nelson units.  The input is slotted, with an ID of approximately 1.9 inches and a body diameter of just under 4.5 inches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2016 at 9:36pm
If it is a Nelson muffler, it would still have that Nelson sound.  They were OEM for these tractors.
