Sprayer tractor?
spencefarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spencefarm Quote  Post ReplyReply Direct Link To This Post Topic: Sprayer tractor?
    Posted: 07 Apr 2016 at 9:35am
I'm trying to decide if I should get another tractor to hook up a 300 to 500 gallon sprayer to. If I were to do this what would you guys recommend as a good tractor to use? We are non certified organic. So we would just be spraying non chemical things if that factors into any ideas.
Edited by spencefarm - 07 Apr 2016 at 9:38am
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 9:54am
Would probably be an overkill for what you have in mind, but my 7580 was my most favorite spraying tractor that I ever used. But I was pulling 1,000 gallons and 100 foot booms. Darrel
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 10:02am
Depends on your budget, type of sprayer(pto or hyd drive pump), anything from a D-17 to 6080 with a cab and air-condition.
Leon B
Johnwilson_osf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 10:07am
We use our 6080 with a Hardi 300 gallon sprayer.  The tractor pulls a full tank with no problems, especially with our side hills here.
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 10:29am
If you are going to spray row crops get a setup like this. I have 36" of clearance under the rear axles.
ALLIS EXPRESS!
This year:
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 11:09am
Really depends on how many acres and what application rate your using. We use a CIH 8910 with a 1800 gallon trailer sprayer with 100' booms. We can't get into smaller fields with it. But most fields are 1/2 mile square. For the smaller fields an old dodge pickup with a slide in unit with 50 foot booms works fine. For fields that get sprayed once a its Cheeper to get the elevator to do than keep a tractor for once around the field.A Row Gator can cover a quater section in an hour all in one trip and travels 40 mph to the field.
critter View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 11:23am
We use a 7040 on the sprayer 500 gallon 60ft boom with hydraulic pump works great, once you get the hydraulic flow set it maintains the same sprayer pressure regardless of engine speed. Probably overkill on hp but it works, 18.4 tires or smaller work good on 30 inch rows.
Edited by critter - 07 Apr 2016 at 11:28am
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 12:06pm
i would get something with a cab. and the 301 engine, cause its a fuel sipper for applications like that. 7000?
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 2:29pm
dad used a d17 on a 300 gal sprayer for years.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 2:30pm
We use to use the WD45 but now I use a single front wheel D17 on a 300 gallon pull type sprayer. Any standard narrow front works in 30" rows the narrower the rear tires the better.
If you're going to spray corn or other tall crops then you need either a high clearance tractor or start looking at self propelled (hi boy) sprayers like an old Hawn or Hagie.
AGCO My Allis Gleaner Company
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 8:49pm
You are hung up on your 7000! A 6080 uses a fraction up the fuel and is much more nimble. We have both been their done that. When we had a pull type sprayer our 6080 played with a 650 gallon sprayer.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 9:05pm
That said, a 7000 is not a bad choice and most likely will be had for half the price of a 6080.
Wink
I am a Russian Bot
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 11:41pm
I bought an old Hagie high boy 4 wheel drive with 500 gallon tank and 60 ft booms, used it for years, worked well and only paid $1500. for it. then I had to change the nozzels once, and that cost me over $600 just for the spray tips! whew! I've sold it already, went to a veggie farm in the south! if you have hills and go this way, DON'T get a 3-wheel unit! they tip to easy on side hills. might try for a older "spray Coupe" see a lot of them on auctions, but never paid attention to the prices! they're the ones that look like an airplane cab without the prop! thay are a lot lower to the ground than a high boy!
8050/8030/185 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8050/8030/185 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2016 at 3:31am
I would pick a 185 with dual PTO or a 6080. For most jobs around the farm today it is almost a must to have the 540/1000 rpm pto. Also the hydraulics of a D17S4 or better is a must.
A-C 608 ltd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-C 608 ltd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2016 at 6:42am
We ran a hardi 500 gallon with a 60' eagle boom. We pulled it with our 7020ps at first then a Ford 7710 (100hp PTO). Now we have a self propelled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2016 at 7:28am
I use a 190xt with 14.9x38 tires 500 gallon tank.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2016 at 11:09am
I may be slightly biased ;)
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2016 at 8:24am
We use a 175 with a 500 gallon demco and works perfect for our use even on a hill and it has a hydraulic pump on the sprayer
If fishing is a sport your looking at an athlete
