manure spreader
JXMARCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JXMARCO Quote  Post ReplyReply Direct Link To This Post Topic: manure spreader
    Posted: 16 Mar 2016 at 9:59am
I have a ground driven manure spreader with the year 1939 on the frame I don't know the model number but it looks very muck like a New Idea 12
I am looking for parts and have had no luck I don't think many of these were made any help would be greatly appreciated
Edited by JXMARCO - 18 Mar 2016 at 11:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2016 at 11:03pm
What do you need
Post Options Post Options   Thanks (0) Thanks(0)   Quote JXMARCO Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2016 at 10:26am
I need this hub and one cog and spring
Edited by JXMARCO - 18 Mar 2016 at 10:40am
Johnwilson_osf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2016 at 10:45am
Do you have part numbers?  I have some NI spreader parts, but I have them by number
John
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2
Post Options Post Options   Thanks (0) Thanks(0)   Quote JXMARCO Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2016 at 10:53am
I have no part numbers and I don't even now the model of this spreader but it looks a lot like the NI-12
Farmuse01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farmuse01 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2016 at 11:26am
I am not real sure, but...I have a 12A New Idea and the front head board is wooden. My dad has both 17NI, and a 206NI and they both have a steel front head boards. Also the upper side rails on those(17, 206) are steel like the one you have. The 12A has more wooded rails with a small piece of angle iron on them. Sorry I don't have any parts but maybe this info will help you.
Jonathan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2016 at 8:05pm
Ok will see if have parts book then see if I can find part number
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2016 at 8:38am
I believe that spreader is an AC 95 G. I have one restored. I have a parts book, I will look up the hub. I think they made 2000 of them.
WD45 Diesel, RC,CA,IB, B, G, 616, Early B-10, D-10, Terra Tiger, 95G spreader, SC blade
Post Options Post Options   Thanks (0) Thanks(0)   Quote JXMARCO Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2016 at 3:25pm
ok hank you also the cog
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2016 at 4:36pm
do you have the part that broke off' it would weld together nice' an still could be used.
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2016 at 1:43pm
The hub is 533886 either side, the pawl is 533831 for the right side and 533832 for the left. Springs are 533922 right and 533923 left. I bought springs at the hardware store and bent the ears to fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JXMARCO Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2016 at 4:27pm
the pawl is 533831 this is an allis chalmers part number
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2016 at 11:59pm
I found the new idea parts book, do you want those part numbers. What side is it
Post Options Post Options   Thanks (0) Thanks(0)   Quote JXMARCO Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2016 at 12:29pm
Its the right side
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2016 at 5:34pm
I might have a pawl in new idea
