Snap-coupler lift latches LEFT/RIGHT
Message Reverse Sort Order
Robert Musgrave View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Musgrave Quote  Post ReplyReply Direct Link To This Post Topic: Snap-coupler lift latches LEFT/RIGHT
    Posted: 16 Mar 2025 at 7:21pm
checked my 1949 "WD" and they are correct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2025 at 7:36am
We have an early d17 and it has the bar across. My great uncle bought tractor brand new from my grandfather. That bar will raddle a little when lifting implements. When plowing you could tell when traction booster was working.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2025 at 6:57am
I have too. And it always seems they were bent inward, which could be caused by a lift latch on the wrong way AND an implements lifting link frozen and not able to twist ??  I'm sure I've never seen one bent outwards.
Edited by DrAllis - 16 Mar 2025 at 6:59am
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2025 at 6:03am
I have seen bent lift arms and thought, how in the **** did you do that???
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2025 at 3:52pm
Thanks Pat and Dr Allis. I would think it would take some serious abuse to break a lift arm. Thanks again
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2025 at 3:12pm
It was a solid shaft. I believe even the last WD-45's had that as an option as did the early D-17's when they had a 4-bottom plow hanging on the back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2025 at 1:01pm
We had a series 3 d17 with a pipe that went through the holes . The series 1 didn't have the pipe between them. I was told it beefed up the arms and were less likely to break one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2025 at 11:49am
What's the purpose of the 1+1/4" ish hole underneath my lift latches? A pipe that something is mounted on? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2025 at 9:19am
Dennis, I might have a book for pin-hitch plows out in the shop, maybe. I do not have any plows that old. Have some 'hands' (have heard them called that) from implements from the pin-hitch era.
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2025 at 8:55am
Showing my age here as well as poor memory.  The early pin hitch plows vintage 1948-2/16 had a sleeve type connection which slipped over the lift arm but was a permanent part of the plow.  Here's where the memory gets foggy, those sleeves had right angle type bolt which preceded the set screw and could be turned in by hand.  Seems like they were on the inside but wouldn't swear to it.  The only way it was wrong was if the plow was assembled wrong since it wasn't a real easy swap to get the locking bolt on the outside.  An ancient plow book might reveal the intent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2025 at 8:41am
Mine are on wrong....
Most, but not all, of mine too. Talked about that in yesterday's video. Got me thinking, should do one sometime about the different generations of latches. I probably have at least one from every generation around here. Will look into that at some point in the future.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2025 at 12:07am
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 11:59am
Story - We went to the auction of the AC plant in MKE. They found 2 tubs of snap couplers, one top, one bottom, one tub of springs, and one tub of rivets, hinge bolts. I bought one tub of the tops kind of by mistake. When checking out I went to the tubs and started taking top halves and mating with bottom halves , springs etc.  Some dealers wife came running up and demanded I stop and put everything back - I told her the tops were of no use w/o bottom latches and we would split them. She was irate and called her hubby who was a dealer and he threatened to call security on me. I told him I had a better idea - he could have them all.  He was clueless. SO, some where, probably in a new product some were by now melted down, are about 100 new snap coupler latches from the circa 1986 sale. I will not mention the old fellows name... a former Nauthurn dealer  :-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 10:39am
My series 1 D 15 has both set screws on the outside. There are holes on the inside but they don't look threaded. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 8:40am
Guess I've got my assignment for the day. Guess I've got 6 tractors to look at, though will probably look at more. Maybe I'll cover this in the video I'm going to shoot today?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 8:16am
Yes. There are some older ones that had only ONE hole, so there were lefts and rights early on. BUT regardless, people install them wrong !! Setscrew to the outside always.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 7:16am
I think it was like this. the originals were 331862 and 331863, left and right, threads on one side. Then in numerical book those numbers say use 243996 which I think threads on both sides
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 7:06am
Most latches (not all) that I've seen have threads on both sides to put the bolt on either side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 6:12am
Good info Dr Allis! I'll check my D 15. Thanks!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2025 at 10:44pm
Thank you!
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2025 at 10:26pm
I'll have to go out and check all 5 sets.  As always, many thanks to the good doctor.  Appreciate it!
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2025 at 8:29pm
I just went and checked mine as I've had them on and off a couple times for repairs. They were on correctly. And yes you can see how that squares them up. Learn something every day!! SmileSmile
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2025 at 8:12pm
Thanks for clarifying. Ive seen a number of them installed as you'd noticed and I had been wondering lately which was the correct way
Post Options Post Options   Thanks (2) Thanks(2)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2025 at 7:56pm
I was out working on a friends WD-45 diesel tonite and he also has a WD-45 gasser. Both tractors had the lift arm latches on the wrong sides. The retaining setscrew/square head bolt ALWAYS goes on the outside. This makes sure the lift latches are "square" to the lifting links and makes life easier on all the components. This applies to all WD/WD45/D-14-15-17-19-190 tractors. Setscrews on the OUTSIDE !!!!
