Rod bearing wear |
Acguywill
Joined: 15 Jan 2024 Location: Vauxhall ab Can Points: 192 |
Topic: Rod bearing wearPosted: 5 hours 22 minutes ago at 1:15pm |
So this is a picture of a rod bearing from the engine I had the antifreeze issue with.
![]() All six bearings have the same mark in the same place. What caused it? It is deep and can easily be felt. The crank looks and feels fine. |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5144 |
Posted: 5 hours 2 minutes ago at 1:35pm |
Antifreeze has/is glycol. Glycol is in the glucose (sugar) family. Antifreeze in the oil reduces the ability of oil to lubricate the crankshaft.
At a very minimum, you have to first eliminate the coolant in the oil. I would change the rod and main bearings. The crankshaft should be measured (miked) to see how out of round it is.
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8334 |
Posted: 3 hours 39 minutes ago at 2:58pm |
Ouch!! |
bigal121892
Posted: 2 hours 51 minutes ago at 3:46pm |
You said the engine had been sitting for four years, I wonder if just the fact that the crank was sitting in that one spot for that long, could have done that.
Les Kerf
Posted: 2 hours 50 minutes ago at 3:47pm |
That doesn't look like frictional wear but rather more like a chemical reaction dissolving the bearing material
Acguywill
Posted: 1 hour 28 minutes ago at 5:09pm |
The bearings looked like that when I parked it. I thought it looked like chemical etching but can't figure out why or how they could all be in the same place, the holes for the oil don't line up in the same place on the bearings. I couldn't find new bearings at the time so it has just been sitting but have recently found some so am looking to get it ready as a spare/backup. Not that it makes any difference but it is an international UR450 power unit. The date on both the rod and mains is 6 74 so it has been a while since it's last overhaul. Forgot to add there was no antifreeze in the oil when I checked it 4 years ago and there is none in it now so thankfully the block did not freeze.
Edited by Acguywill - 1 hour 25 minutes ago at 5:12pm |
Posted: 1 hour 7 minutes ago at 5:30pm |
If you're going to re-use them, switch them around, top shell to the bottom and bottom shell to the top.
Acguywill
Posted: 37 minutes ago at 6:00pm |
I had thought about that, but the bad spot is on the bottom shell as it is and the edge of the spot is very abrupt. I was worried that if I ran it the bearing material would continue to break down and destroy the crank. Parts for old International engines are getting scarce.
