Question on an 80 series plow |
KevinON
Joined: 07 Dec 2009 Location: Schomberg, ON Points: 804 |
Topic: Question on an 80 series plowPosted: 10 Apr 2011 at 9:40am |
On my 80 series mounted plow that I recently acquired, the front coulter beam has been cut off, and the reason why, I believe, is that the beam would interfere with hooking up to the tractor. Do I have to run without a front coulter? Thanks.
Posted: 10 Apr 2011 at 9:48am |
Maybe it was used on a brand X tractor that the drawbar was in the way??
KevinON
Posted: 10 Apr 2011 at 11:01am |
No, the plow seems to be just too close to the tractor. Even on my 180, it seems awfully close. I don't know how long the original bracket was. I will be hooking it up again this week, so I will take a photo and post it.
Gerald J.
Posted: 10 Apr 2011 at 12:46pm |
In my plow bottoms book, all flat coulters mount to the plow beams. On my 2000 plow because the shanks are taller there are coulter beams on the plow shanks.
Gerald J. |
Skyhighballoon(MO)
Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Posted: 10 Apr 2011 at 2:20pm |
On my 4-16 Model 74 3-point plow I use on my One-eighty, the front coutler runs very close to the right 3-point lift arm. This would cause the plow to plug badly with corn stalk trash. I removed the front coulter and that eliminated the problem. No difference in how it plows otherwise with the front coulter off. Mike
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
KevinON
Posted: 10 Apr 2011 at 3:08pm |
Thanks, guys!
