Pressure Testing Old Tractor Cooling Systems
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: Pressure Testing Old Tractor Cooling Systems
    Posted: 19 Sep 2026 at 9:30am
What's everyone's favorite way/tool to pressure test radiators and such on our old AC tractors? I almost picked up a radiator pressure testing kit from Harbor Freight the other day but it didn't look like any of the cap adaptors would work.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2026 at 9:34am
I used one from AutoZone on my D 15. Had to put up a deposit but got it back when I returned the tester. Good luck
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2026 at 9:35am
An air compressor and a leather or rubber glove. Just be careful not to over pressure it.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2026 at 10:33am
I "borrowed" a test kit from O'Reilly. Paid the deposit, (full retail price) and never returned it. Of all the test caps in the kit, the only one I've been able to use is the rubber expansion cap. I've used it so many times over the years I don't miss the "deposit".
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2026 at 2:28pm
In the past I have made up a hose fitting with a T in it , then using a regulator to control air pressure just charge system ( on trucks and cars ) using present cap on radiator .
 On tractor one would need to tap into block drain with a T and gauge and valve .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2026 at 3:25pm
Have my own, bought close to Forty years ago, have to take apart and lube the piston ring occasionally but make pressure just fine and gauge is as accurate as I need.  Used on Allis 7G as well the 180 and numerous OLD Cap Style cars or trucks.  Not bought a update cap style for the screw on caps.
Edited by DMiller - 19 Sep 2026 at 3:25pm
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2026 at 9:50pm
I use my MerCruiser outdrive pressure tester.  I make up a 'dummy' cap to replace the normal, and hand pump it only a pound or two higher than the original cap pressure rating.  This doesn't test the CAP... it just tests the system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2026 at 9:19pm
The rubber expansion style is what I'm leaning towards. I have a cheap pressure/vac hand pump from testing chainsaw crankcases already, so I may be able to get away with a couple sizes of those rubber expansion caps.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2026 at 5:36am
I have one like this but it doens't work on my 185. Does anyone know of an adapter I could get so I can test my 185?
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2026 at 6:24am
How does it not fit?  The radiator neck is too deep?  Wrong diameter?
Some kits, like my STANT kit, have one or more thick rubber washers that can be used under the tester cap seal gasket for radiators with deeper necks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2026 at 1:56pm
It's the right size but the neck is too deep. one or more thick rubber washers is a good idea if I can find the right size. I cna press the cap down all the way and it will seal but of course I can't hold it down while I pump or look for leaks
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2026 at 10:52pm
I cut some washers out of old inner tubes to pressurize the radiator on my Model C
This page was generated in 0.107 seconds.
