Pressure Testing Old Tractor Cooling Systems |
wjohn
Topic: Pressure Testing Old Tractor Cooling SystemsPosted: 19 Sep 2026 at 9:30am |
What's everyone's favorite way/tool to pressure test radiators and such on our old AC tractors? I almost picked up a radiator pressure testing kit from Harbor Freight the other day but it didn't look like any of the cap adaptors would work.
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3362 |
Posted: 19 Sep 2026 at 9:34am |
I used one from AutoZone on my D 15. Had to put up a deposit but got it back when I returned the tester. Good luck
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1422 |
Posted: 19 Sep 2026 at 9:35am |
An air compressor and a leather or rubber glove. Just be careful not to over pressure it.
plummerscarin
Posted: 19 Sep 2026 at 10:33am |
I "borrowed" a test kit from O'Reilly. Paid the deposit, (full retail price) and never returned it. Of all the test caps in the kit, the only one I've been able to use is the rubber expansion cap. I've used it so many times over the years I don't miss the "deposit".
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42478 |
Posted: 19 Sep 2026 at 2:28pm |
In the past I have made up a hose fitting with a T in it , then using a regulator to control air pressure just charge system ( on trucks and cars ) using present cap on radiator .
On tractor one would need to tap into block drain with a T and gauge and valve . |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 36570 |
Posted: 19 Sep 2026 at 3:25pm |
Have my own, bought close to Forty years ago, have to take apart and lube the piston ring occasionally but make pressure just fine and gauge is as accurate as I need. Used on Allis 7G as well the 180 and numerous OLD Cap Style cars or trucks. Not bought a update cap style for the screw on caps.
Edited by DMiller - 19 Sep 2026 at 3:25pm |
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6165 |
Posted: 19 Sep 2026 at 9:50pm |
I use my MerCruiser outdrive pressure tester. I make up a 'dummy' cap to replace the normal, and hand pump it only a pound or two higher than the original cap pressure rating. This doesn't test the CAP... it just tests the system.
wjohn
Posted: 10 hours 60 minutes ago at 9:19pm |
The rubber expansion style is what I'm leaning towards. I have a cheap pressure/vac hand pump from testing chainsaw crankcases already, so I may be able to get away with a couple sizes of those rubber expansion caps.
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3174 |
Posted: 2 hours 43 minutes ago at 5:36am |
I have one like this but it doens't work on my 185. Does anyone know of an adapter I could get so I can test my 185?
Jim.ME
Posted: 1 hour 55 minutes ago at 6:24am |
How does it not fit? The radiator neck is too deep? Wrong diameter?
Some kits, like my STANT kit, have one or more thick rubber washers that can be used under the tester cap seal gasket for radiators with deeper necks. |
