Looking at getting a new to me disc opinions wante
rudyk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rudyk Quote  Post ReplyReply Direct Link To This Post Topic: Looking at getting a new to me disc opinions wante
    Posted: 15 May 2017 at 9:40pm
Looking to replace my John Deere 13' bw disc
Use it on about 30 acres or so, fairly rocky ground
Will be pulling it with a 190xt diesel
Looking for a solid unit with parts availability
What are your suggestions thanks
IHCfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IHCfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 10:09pm
Don't know anything about allis disks but I would say a IH 18 foot 470 would be a nice cheap option if you need a heavy disk and your not plowing or chisel plowing a 480 is a nice heavy disk
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 11:11pm
to bad they dont make a wishek disk small enough for you thats what we use on heavy rocky soil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 12:26am
I agree....that if you can't find an AC disk, go with the 470 IH, they are great disks too! I been seeing a lot more die hard green famers now pulling red disks! the IH 480 is a heavier disk and will pull a bit harder, but will really chop and grind that soil up. any one you chose, should be a 9 inch spacing if doing stalks. a 7 inch spaced disk won't go in as deep or grind up the soil unless it's already been plowed or disked once/twice before using it. they do a good job of mixing chemicals in already tilled soils.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 12:31am
also 490 IH and 496 IH disks are good too. I have a 496 and only complaint is they use cast iron holders to hold the scrapers on. they used to be steel and worked great, now they are cast and break a lot. I fought with them, and finally had a welding shop make me steel ones and problem was/has been solved. the Case IH dealer said they sell a lot of them cast iron brackets!
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 6:34am
Pulling an 18 foot heavy disc with a 190? Phew...if you say so!
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 8:00am
DAD bought a 16' 470 and pulled it with his 190xt, with a new motor and rebuilt fuel system it was all the 190 wanted, it was a great disk.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rudyk Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 8:23pm
I've got a 13' footer now
Don't think I want anything more than a 15 max
Post Options Post Options   Thanks (0) Thanks(0)   Quote rudyk Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 8:33pm
What do you feel is the best allis disc out there
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 8:56pm
IMHO, the best Allis disk, would be the 2500 series, but, I don't know if you can find one small enough to pull with your 190XT. Your next best choice, would be an Allis 2300 series. More of a finishing disk, similar to a IH 470, I think. These are also very good disks.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 10:04pm
Sunflower
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 5:14pm
Had a 480 disk, did not do well in rocks, think there are better one.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 12:15am
The only suggestion I have is to buy a disk that will take 150 hp, then you will be "forced" to buy a 7060 or 7080. :)
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rudyk Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 7:58pm
I better stick with my 190's
Sagefarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sagefarmer Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 8:39pm
We have a AC 2300, I think it  is 14'.   It is a good disc.  We have not pulled for several years.  Our equipment is much larger and we don't have a need for it.  If you could find one in your area I would recommend it.  They cut well for there weight and ours kept soil level.
This page was generated in 0.107 seconds.
