CA crank pulley removal
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: CA crank pulley removal
    Posted: 14 Nov 2023 at 5:15pm
I only looked at this briefly. Socket won’t fit cause pulley sheaves in the way. Screw head didn’t move. What is the combination to crack this case? 🤔Thanks! Dana.
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2023 at 6:27pm
Crowsfoot wrench.  Be sure to make a horseshoe plate to support as much of the pulley as possible before pulling with a puller or you'll crack the pulley for sure. It also helps to warm the pulley good before putting it back on.
Edited by PaulB - 14 Nov 2023 at 6:27pm
ORBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ORBill Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2023 at 8:01pm
What Paul says. I just did mine. Soaked it with penetrant, ground a little off an old wrench to sort of fit, nut broke loose then screw came out pretty easily. I did break the tip off a screwdriver trying to get the screw out without getting the nut loose first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2023 at 8:20pm
Ok thanks y’all
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2023 at 9:40pm
Loosen the nut but leave it in so the screw slot doesn't spread open.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2023 at 10:20pm
I'm lost on this Paul.  Support the pulley?  Do you mean to put the plate behind the pulley and then pull against the plate?  Thanks
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2023 at 6:03am
I used a bearing separator to pull the pulley off a b. You have to support the bearing so you're not pulling against the pulley itself. Yea lube and maybe heat. Good luck.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2023 at 6:06am
I use a two jaw bearing splitter with two pulling rods, a threaded cross beam and forcing screw for these. Think I have four different sizes of bearing splitter so something always works. Long and short is you need to support that sheave almost complete around it's backside while forcing on the crank snout.
That's All Folks!
