WD allis coil
Kenter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenter Quote  Post ReplyReply Direct Link To This Post Topic: WD allis coil
    Posted: 01 May 2024 at 8:51am
I have a WD that has been converted to 12volt, the tractor has the external resistor , Do I have to buy a new coil that does not have a resistor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 9:33am
the external resistor is a PATCH to make a 6 volt coil work on 12 v.. If it is WORKING, thats OK... When it dies of old age, its time to get a REAL 12v coil that is Internally wound with the right reistance and then Eliminate the External resistor.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 10:47am
Get a new 3 Oem coil , as Steve said why patch it with resister ,most guys don't even use correct resister and that causes problems .
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenter Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 12:53pm
When you say right resistance is that just a regular 12 volt coil with internal resistor, or is there a certain one I should get for the WD?? Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 1:14pm
YES... there should be a lable on the coil that says " 12v with internal resistor" . ... not really an actual resistor, but wound for correct resistance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 1:16pm
this one actually says "no external resistor needed" on the case... AMAZON
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 1:37pm
The UC 15 T is a    3 oem    resistance    coil  for  any  4 cylinder  engine   12  volt system
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenter Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 2:52pm
Thank you
