Paint technique
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Paint technique
    Posted: 15 Sep 2016 at 6:29am
After doing a few tractors, what is your best technique for doing the bottom of the tractor?
I have a top fed gravity HVLP gun and it is hard to manage laying on my back.
Use a smaller gun?
Charlie
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 6:53am
I use the same setup and manage to get mine covered well enough.  The trick is to paint underneath when the cup is full and when it becomes hard to keep paint going to the tip you finish out the cup painting on the sides.
 If you actually want it too look as nice up side down and as it does right side up I suggest turning it upside down to paint the bottom of itWink
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 7:45am
Ok...my guilty moment...when I painted my 8N, I had the same problem, so I figured "No one looks underneath anyway", so I just brushed the paint on underneath. Shocked
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 7:48am
Chain Hoist up the front as high as you dare and get after the bottom of it with the gun you have. Your cats and dogs really do appreciate a nice paint job on the bottom of tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 8:04am
My cousin never fails to come look at a tractor and loves to point out any issues....Confused
Charlie
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 8:28am
I learned that you can never have enough light when you paint. I will use several
"clamp lights" to illuminate the work when I paint the next one. Bob@allisdowneast
I used to think I was indecisive, but now I'm not sure.
lockheedt33 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lockheedt33 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 12:07pm
The best way to do it is get a 3m pps adapter for your gun and use the pps system. It's got a cup with a collapsible plastic liner. You fill it with paint, put it on the gun, turn the gun upside down and spray until it sucks all the air out of the liner and then your gravity gun will spray in any position. The cup liners are disposable so there's a cost there but I've found it's pretty much break even at the price of solvent for cleanup anymore. With the pps I might use 1/4 to 1/2 pint of solvent to clean the gun.
1941 AC B
1948 AC C
1951 AC CA
1954 AC WD45
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 9:17pm
Lockheed 33 explain a little more if you will about the gun.i would like to get something like that...oh by the way how was you associated with the t bird ?had one in base op in west texas,fine airplane.....
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 10:59pm
you should have never let that out Creston!
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2016 at 2:51am
My brother used his backhoe to pickup my d15 when he painted it so he had access to the underside standing it up vertically. The backhoe was a ford 555 so the over spray of po2 made it look better... if nothing else it is an excuse to buy a backhoe and I am sure we all need one of them....
