8050 Hydraulic Remotes are Slow |
jstewart ![]() Bronze Level ![]() ![]() Joined: 14 Sep 2009 Location: NE Missouri Points: 43 |
![]() ![]() ![]() ![]() ![]() Posted: 11 Apr 2012 at 9:43am |
Tried to turn the t-handle on the remote valve, didn't seem to make a difference. Are they threaded; or spring loaded and I need to push in on them as I turn to make them catch a notch or something. As I was standing at the rear of the tractor I was turning them counter-clockwise, and I turned them quite a bit, but it didn't seem to make a difference.
Thanks for any help. Jared
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21855 |
The roll pin on the flow control spool should have a long side and a short side.....long side straight down is fast......long side straight up is slow.
Thanks a million DrAllis, I'll give that a try tonight.
Now that I'm home and relaxed, I gave you bad advice.....Long side down and up is for 7000 series........I think the 8000's were 3 o'clock and 9 o'clock.....only one-half turn from fast to slow.......you can turn them 100 times and it does nothing, it's where you set them at.......put one and 3 o'clock and the other at 9 o'clock and you'll figure it out. THIS INFO IS IN YOUR OWNERS MANUAL with pictures.
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8716 |
Look under the seat, towards the back of the cab. Could possibly be a flow control for one of the remotes there with a decal showing fast and slow. Orientation of the rest of the remotes is the same. Darrel
BobHnwO ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Jenera Ohio Points: 693 |
The handle on my 7060 was on backwards!
Thanks for the replies guys. I didn't take much time to mess with them last night, I put both of them down and one seemed faster than the other so I switched my raise/lower to that remote. I can attest to turning them and nothing happening, I about wore out my fingers the other day turning them to no avail. There is a picture under the seat with a fast/slow, I assumed (know what that will do) it was indicating the direction to turn the t-handle, not indicating a position. I'll get back to it again tonight if it doesn't start raining early.
Thanks again, Jared
