"Belly Filters"
tbran View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Topic: "Belly Filters"
    Posted: 19 Jan 2025 at 8:36am
This is just a comment on several issues we have had in the past year. For some reason we are having problems after a filter change - with after market and OEM filters - with customers having a complaint of no hydraulic flow. About 10% of sales. The problem is either the filters are a very small degree shorter, or are 'crushing' a very small amount and not allowing the 'trap door' to fully open.  What we are doing is removing the cork gasket from the old filter and glueing it to the new one. That is working. IF too thick a gasket is added it collapses the filter. IF the cork can't be removed a 'made' thin gasket will work.   The symptoms are noisey cavitating remotes, especially when cold, and steering issues.
Edited by tbran - 19 Jan 2025 at 8:39am
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2025 at 8:41am
That could be the answer to the issue I've been having with my 7060. Be a while before I can check it out, but it's a great place to start. Thanks Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2025 at 9:09am
Thanks for that info- what kinda glue works for that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2025 at 10:28am
loc-tite products or just a 'thin' coat of silicone. Doesn't take much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2025 at 10:41am
We always use to roll on an Oring of the right size diameter onto the screen and then place the screen in the end of the filter as usual. Oring fatness was approx 1/4" to be sure the door got opened plenty. Oring for reused for the next filter change. I'd been doing that for 40 years because we had some problems a long time ago, so it became just a standard practice for us.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2025 at 1:42pm
Im glad to see this post because Ive got an 8070 that doesnt act just right
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2025 at 2:40pm
I've changed filters and fluid on a 7010 recently, and the remotes make that cavitating noise a lot, especially when cold. I'll look into adding an O-ring as doc suggested, since I've already discarded my filters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2025 at 3:28pm
Everything hydraulic begins at the left-hand belly filter. If that spring loaded door isn't being pushed open enough, there will be nothing but trouble. Thee most common issue is the screen not being transferred over from the old filter to the filter.
SilverShoes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2025 at 6:44am
Are all OEM Agco filters being made correctly?
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2025 at 3:09pm
Tbran, thanks for sharing your knowledge. Would these filter issues have any influence to cause belly filter caps to leak constantly?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2025 at 4:01pm
7000 and 8000 series had different sealing Orings. The 8000 are larger in diameter than the 7000 series. Make sure you have the correct ones, I learned this the hard way. Even had a parts guy tell me there isn’t a difference but there definitely is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2025 at 7:34pm
For 45+ years I've done it like this.  7000 series ...if either Orings aren't damaged, I don't use the new ones. Wipe the outer Oring with a rag that has brake kleen on it to get all oil residue off that area. Wipe the filter cover LID with the same rag with brake kleen. Run a bead of RTV silicone around the lids edge and put it together. You will have no leaks.
Edited by DrAllis - 21 Jan 2025 at 1:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2025 at 9:25am
These belly filters are a little intimidating. I've always tried to pay attention to the order of things as they come apart and reinstall accordingly. A good video of the procedure would be helpful. There are instructions with AGCO filters but after Tim and Doc's comments I start second guessing things. Do the filter housings(the big tube) ever get pulled and those orings replaced? I never have. What is the little sender on the rt side return filter head for? Isn't that what turns on the HYD filter light? That light is on a lot on my PD 8070 but everything seems to work ok. I changed both filters when it first started  flickering to no avail. I've chased that wire and can find nothing wore through to ground it. Often wondered it some metal particals are in the sender causing it to make contact and ground out. I may be off base and not understand how it works.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2025 at 12:47pm
Oil would have to be drained to change the filter housing seals. I’ve got a 7045 that they leak and need resealed. Just hasn’t been a priority project
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 12:41am
Hello. Going to be changing these filters on 8000. New to us and remember this post. Was thinking what if last guy in there did it wrong, so what’s the problem areas to look at and make sure are correct.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:21am
If the hydraulics and power steering have been working correctly, it is highly doubtful that anything is wrong. Be sure to remove #8 screen from the old filter and transfer over to the new filter. Do NOT assemble either side bass-ackwards. Your owners manual has good pictures showing which way things go. If there were no leaks at the covers, I never use new Orings and lightly RTV the lid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 9 minutes ago at 4:41pm
I haven’t been in it much myself and don’t think any steering issues but hydraulic noise.
