hd 6 g serial # |
gemdozer
Posted: 20 Jul 2012 at 11:50am |
The HD6G later serie the head motor is different and should have a crossbar betwen the 2 finder and the hydrlic hose are attache on and for changing the stering cluch you need to drain the hydrolic tank and removed the cylinder hoses and crossbar.
ratchet
Silver Level Joined: 16 Jul 2012 Location: texas Points: 51 |
Its a 1963 model the higher serial # Thanks for all of the help!
ac_sd
Silver Level Joined: 23 Apr 2011 Points: 194 |
That "8" could be a worn off "G" also....... If it has a 344 engine its likely a 1637 s/n, if it has a 6000 engine its likely the higher s/n.....
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29703 |
I suspect you dig a little harder at the rear and that '8' will come up, too close a number on both to not be the same.
gemdozer
Yes must parts are the same in the 2 machines
ratchet
I need assistance identifying a hd6g I just purchased. There is a plaquard on the dash that has hd6g-16378, and on the right rear of the machine stamped hd6g 1637 any help idemtifying this machine would be appreciated, also i have a hd6g 1956 model are the parts interchangable??
