Allis 8050 engine build
 Post Reply Post Reply Page  <1 2345>
Message Reverse Sort Order
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2015 at 10:06pm
5 hole Mack tips need to be turn a 1/4 turn to be correct.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2015 at 10:05pm
Why do you have the injectors in 1/4 turn off? Unless the tips are drilled to be in 1/4 off you will loose power , smoke, and be hard to start.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2015 at 5:41pm
Well, got it bolted up to the Bellhousing today. Got the turbo and injection lines on too. Got the frame rails all cleaned up and ready to put on. That's tomorrows job.
On this pic, you can see that you have to grind out alittle on the front plate for the rack cap. Still is sealed good by the gasket.
Edited by peterson - 13 Apr 2015 at 5:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2015 at 10:25pm
Also, seeing this is the PRIMARY oil filter and only filter on the Cat D6D Dozer of ours with a oil change interval of 250 hours. I feel that having this as the By-pass filter on a tractor that has its oil and primary filters changed at 60-70 hours and by-pass filter at 120-140 hours will be more just as good as the "FACTORY" filter.
Edited by peterson - 12 Apr 2015 at 11:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2015 at 10:13pm
I don't think ANY manufacturer actually makes their own filters, but they do set the specs and oft times will-fit filters are not spec'd exactly the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2015 at 10:09pm
I like the crack about aftermarket filters too. You really think Case Ih or agco make there own filters? And CAT filters are not "aftermarket"
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2015 at 10:06pm
I ran the Donaldson equivalent to the CAT filter on our 8050-70's for many thousands of hours and never had a problem and yes it is a 20 micron full flow filter. I do see you left the restrictor on coming off the oil cooler which is good. I really feel the extra oil capacity was the main idea behind the extra filter. We've used Delvac 15-40 since it's conception and at that time changed @ 100-125 hrs. Not trying to argue Doc as I see your point also. You've got a great project going , keep us posted. Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2015 at 10:05pm
What's the micron rating of the Agco filter? And is that rating single or multi pass.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2015 at 9:36pm
The AC luberfiner filter is a low volume, very fine micron, intended to extend oil change intervals. A filter that is larger micron won't accomplish the intent of the luberfiner design.
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2015 at 9:22pm
I'll agree with you there DR. It cracks me up everyday when people get aftermarket filters cuz they are cheaper. Odds are its for a good reason. Equipment is designed to run a certain micron filter. I prooved it this winter and its been prooved in our shop at the case IH dealer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2015 at 8:55pm
What's the micron rating on that Cat filter??? I doubt that it's as fine/small as the AGCO luberfiner filter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2015 at 8:49pm
Lol he did it to the one he drives, the 8030, now the 8070 needs it done too. Poor things are slowly rotting away...
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2015 at 8:39pm
what a nice brother!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2015 at 8:37pm
Almost ready to put in the tractor.   Just need to get a few little things that didn't come in the kit. Here's a few pics of the progress.
Also have been doing alittle filter crossing and came up with this CAT filter for the By-pass. Its only $12 bucks at the local Cat dealer. Instead of $20 bucks for the Agco filter.
And this is what my brother has been doing. Took up the mat and cleaned all the old dirt and who knows what else. lol here's a pic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2015 at 8:19am
Sorry I haven't posted a update guys, been working on the engine, but haven't had time to take many pics, I will get some uploaded later today or tomorrow. Got the head torqued down, and the engine painted yesterday. Prolly put it in tomorrow, got to run to town and get a few little things for the farm today. More updates to come.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2015 at 9:56pm
Keep posting. I'm very interested in seeing the progress
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2015 at 3:17pm
get a gram scale and balance both ends. Takes lots of time.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2015 at 2:05pm
What's your method for balancing connecting rods?
Not trying to pry, I'm just curious. I've never done it.
I really enjoy seeing & reading what you share - thank you.
Please keep it coming...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2015 at 10:11am
Rods balanced within 3-4 grams of each other. The were 25-30 grams difference...
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2015 at 9:47am
well, a stock 4440 which is a 466 is 98cc @ 2200rpm, and that should make for a 130 pto hp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2015 at 9:44pm
And according to KcGrain, a 140HP pump from a deere will give the 426 190HP. So if Ed would chime in on how many CC's a 4450 or whatever deere that's 140 hp we could figure it out.
Edited by peterson - 03 Apr 2015 at 7:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2015 at 9:41pm
Bigger lines do nothing for HP. Injectors will flow about the same amount of fuel. Hp will depend on the injection pump and turbo. Turbo because you will be getting a cooler more dense air charge, and pump because of more fuel. Seeing that our 220 has pretty much the same setup but it has 140cc of fuel, she is at 220 HP at 1000 PTO rpm. So seeing that the hydro pump of the 8000 series take more HP, im guessing around 210-220. But I guess we will see. When its back together, I will be taking it for a drive to the local dealer and put it on the dyno.
studer automotive View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2015 at 9:25pm
I think 210-220 is a little light on the hp estimate. With the S300 & upgraded pump, injectors& bigger lines it should be around 240-ish.....
a-c 185-d y/r cab turbo soon
99 f-250 7.3 4x4
86 mustang5.0 owned since 8/93
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2015 at 5:28pm
Got the other front engine plate back today. Got the 3 other holes drilled and the top ground out for the rack cap.
The bottom left hole in pic will need a very short headed bolt to clear the idler gear inside the front cover.
And why I say other 3 holes drilled is because the top right hole is one that's factory for the roosamaster.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2015 at 7:01am
Thanks!!! I appreciate the kind words!!! And you can send it up whenever!! lol I wouldn't mind getting in to doin engine rebuilds for ya guys!
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2015 at 12:08am
Man oh man that looks factory. You should be very proud of your work. When can i send you up my 8070????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2015 at 9:54pm
Well guys, Finally got the rest of the engine back from the machine shop. Now to balance the rods and pistons. Then Assemble it!!! WOO-HOO!!!!! Here's a pic of the finished lines. I will be making a little brace to go from the clamp to the block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2015 at 6:58pm
O also guys, if your wanting to mount a A-pump on your tractor, get the adapter plate and hub from Mr. Kcgrain on this forum. He put Lotsa time into that adapter. I would have bought one from him for this but I had this drive hub along time. So figured I'd use it. He also has injection lines too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2015 at 6:56pm
Here's some pics of the turbo mockup on the old engine.
Pic of the S300 turbo
And finally a pic of the injection lines, then need to be clamped together and tweaked alittle, but you get the picture. Lol
Damn i hate bending lines!!! Try to make them look halfway decent...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2015 at 10:13am
Here's a pic of a set of FVP injector hold downs with the return line on our 220.
The return line will look just like this but the hold downs that I will be using are just 3/8" thick steel cut with a water jet.
Edited by peterson - 26 Mar 2015 at 10:14am
