loader joy stick haudraulic feed
barhum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote barhum Quote  Post ReplyReply Direct Link To This Post Topic: loader joy stick haudraulic feed
    Posted: 06 Feb 2015 at 9:14am
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2015 at 2:28pm
Barhum....must be ina snow storm...can't see his post!
Post Options Post Options   Thanks (0) Thanks(0)   Quote barhum Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2015 at 6:20am
new to this. looking for input on how to tie in joy stick valve to haudraulic system on 180 deisel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2015 at 7:43am
You need an "Open Center-Power Beyond" type of joystick valve capable of 2,500 psi. There's two steel lines directly under the battery box area. Split the larger of the two lines at the connector point. Make two (2500 psi)hoses to go from the new joystick valve down to these two connection points. The line that directly connects to the tractor hydraulic pump goes to the "IN" on your new valve. The "OUT" on your new valve goes back to the remaining line. There is an important 3rd port on the new joystick valve that must go back to the hydraulic system sump to relieve any pressures that need to be vented. I hate to route this third line to the sump drain plug underneath for location reasons and I have seen the internal suction screen damaged from this type of configuration. Best advice is connect it elsewhere like tap into the return line after the hydraulic filter.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2015 at 8:22am
make sure your hyd lines are not restrictive - we have seen 1/2 hos fittings restrict down at swedge fitting to heat oil. We use 5/8" ID hose minimum.
