460 loader/185 allis |
Davej ![]() Bronze Level ![]() Joined: 15 Apr 2012 Location: Huntsville,MO Points: 7 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Apr 2012 at 1:03pm |
Bought a really nice 185 last spring, very pleased with it so far. Tractor had a loader on it, but was not on it when we bought it. Found a 460 allis loader that was removed from a 6080 and guy that sold it to us, assured with alittle modification, it would fit. Know we will have to make brackets for the axles, using U-bolts. Concerned about the spacing. We measured a 6080, looks like we need to add 1/2" spacer on each side. Any suggestions on mounting this loader. Tractor has a cab.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21850 |
Make sure you have heavy tubing or heavy angle iron go under the rear axle so you don't break the tractor in half.....been there.
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8339 |
I,m gonna do the same to a 180 , it can be done , have to drill a couple new holes in the frame too - and make sure to brace it like the Dr said or it will break the PD houising
Thanks for all of the info. I will have to drill that new hole in the frame. Will you be leaving the wrap around weight on the front. Also, do we need to put 1/2" spacers on each side of the frame to spread the loader out. The 6080 that I measured was 1" wider then our 185. Nothing like a good project.
