Drag disk to SC disk |
Author | ||
Josh Day ![]() Orange Level ![]() Joined: 29 Nov 2010 Location: Indiana Points: 3427 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Dec 2011 at 8:49am |
I was wondering if there is any way to convert an old drag type disk to a snap coupler lift disk to pull behind a CA. Does any one have any pics of one? Or is this even possible? Thanks Josh.
Sponsored Links | ||
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87693 |
It would be easy enough to put the eye and beam onto the old disc, but your lift arms grab a rigid frame of the disc to raise it. Lot of old pull discs dont have much of a frame and are kind of floppy in the center. You would need a disc that had a rigid angle iron frame all around it.
stray ![]() Orange Level ![]() ![]() Joined: 16 Aug 2011 Location: Tipton, Missour Points: 323 |
The one AC drag type disk that I was around I would say "No way." It would have been a load on a CA anyway. If I remember right it was about 8' wide and pivoted in the middle, You had to set both the front and rear halfs to the disired cut angle. I don't know if all the drag type disk that Allis made was this way or not.
1969 190XT series 3
Rfdeere ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Idaville, IN Points: 3283 |
I don't think Josh is talking about using an Allis Drag Disk.
http://www.rumelyallis.com |
powertech84 ![]() Silver Level ![]() Joined: 17 Oct 2009 Location: Wisconsin Points: 470 |
I dont think it would be to bad of a job to convert a new compact utility type three point disk to work. I'm thinking like a king cutter, or frontier brand 4-5 ft rig.
No, any brad of drag disk. I was just thinking of mabey a later project if its not that hard to do. |
