STP oil, is it good? |
JM
Joined: 12 Sep 2009 Location: United States Points: 379 |
Topic: STP oil, is it good?Posted: 09 Jul 2011 at 9:37pm |
Grandpa put stp in everything. Does it really do any good? Just seems to be a thickiner for the oil. Why not just run a heavier oil? What do you guys think?
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42086 |
Posted: 09 Jul 2011 at 9:46pm |
Use to use it in everything but my cycle. Seems to make oil sticker and cling longer to things. use it as a assembly lube on engies on rod and main bearing . Works best if you add with engine running and hot as mises faster with oil.
New oils I think are formulated better now than they were 10 or 15 years back ann new engines now again call for lightweight oils of 5/30 or 10/30 ..
Jeff Z. NY
Posted: 09 Jul 2011 at 10:29pm |
And alot call for 0w-20 when running alot in below 0 temps.
STP is an anti-fricton additive that puts a thicker barrier between parts even when it's hot and looks thin. Similar to Lucas Oil Additive. I don't believe it can damage anything but then most oil companies so don't put any additives in their oil because thay say it can breakdown their oil faster. Who knows????? |
bwp
Posted: 09 Jul 2011 at 10:35pm |
I am not sure about STP, but I know some oil additives have zinc phosphate which helps as a high pressure metal to metal lubricant. All oils used to have it but it brought catalytic converters a premature death, thus increasing emissions, so the EPA regulated it's use to only off-road and performance oriented applications. Run of the mill oils don't have the zinc. I'd check to see if it has the zinc.
Brad |
Unit3
Posted: 09 Jul 2011 at 10:42pm |
I remember the TV ads. They dipped a straight screwdriver tip into oil and STP. Then they would try to pickup the screwdrivers by pinching them with their fingers. You can't hold onto the on with STP. I have on the lid of my toolbox a STP sticker given to me when as a kid. Our family got to tour the Indy Speedway, and our tour guide handed one some me.
beeman
Posted: 09 Jul 2011 at 10:44pm |
Have not used STP in years in an engine. Rottela ,mobil 1, others work just fine without additives. But it still works good in older gearboxes [brushhogs] or finals that call for 90wt and 140wt. ,non posi rearends. Quiets them down if worn almost out..LOL.
I would not use it in any older tranny that shares oil with its hydraulics,like a B or C,etc. |
1949 B 3930 Ford- Have owned other Orange ,green,red,yellow,dark green tractors and equipment.
Toscani NE SD
Joined: 21 Jan 2011 Location: Milbank S.D. Points: 369 |
Posted: 10 Jul 2011 at 5:37am |
now it's called lucas,same thick stuff
